transmission fluid
Old Sep 11, 2011 | 04:40 PM
chimacc's Avatar
chimacc is on a distinguished road
Default transmission fluid
my 96 blazer ls check engine light came on last nite car has been running hot lately and the trans was was tottaly dry i stoped at a gas station and they only had too left of difrent types one was thicker red the other was a clearer less thick type how many quarts and should i put in? a specific kind or brand?
also will mixing too different types hurt? will go and see the problem code now
and
Old Sep 11, 2011 | 04:54 PM
xgiovannix12's Avatar
Depends how much is needs i say add till it reads correctly on the stick
also wait 10 mins for the fluid to go into the pan before checking if you dont wait you can get a false reading
If its a automatic use regular atf
Old Sep 11, 2011 | 05:54 PM
chimacc's Avatar
ok thanks i let the it run for 25 min put it neutral and levels look good the check engine code was a p0442 evaporation system leak not sure what too do about this one
Old Sep 11, 2011 | 07:47 PM
this should help you with that code
https://blazerforum.com/forum/diagno...plained-35144/
BrinkDiamond
Mar 2, 2014 03:50 PM
SteveCZ28
May 22, 2010 08:25 AM
DaleA
Jan 13, 2009 08:50 PM
p_j_robertson
Jul 3, 2006 09:52 PM
medion42
Mar 16, 2006 10:18 PM
