transmission won't shift, no speedo, odo
Old Jul 18, 2016 | 02:11 PM
cleburne red's Avatar
Default transmission won't shift, no speedo, odo
So, my blazer decided that it doesn't want to shift out of first gear. Neither the speedometer or odometer work. But when I plug my scan tool in, it displays the vehicle speed. Also, when I shift to 2, the transmission will shift to 2nd. OD, D, and obviously 1, all stay in first gear.
TPS is reading correctly, also.
Tried searching, couldn't find any help. Thanks for any ideas.
It's a 1995, 4L60E.
Old Jul 18, 2016 | 04:19 PM
Lots of reading and searching, looks like I'll try a new vss. Hope it fixes it. Hate throwing money and parts at a problem...
Old Jul 18, 2016 | 04:46 PM
newguy's Avatar
actually thats what I was thinking
Old Jul 18, 2016 | 04:54 PM
Well, you was thinking right. $98 and a new VSS later, it's shifting fine, speedo and odo both work!
In the other threads, people said they would have an ABS light as well. I didn't, but that's cause I removed the ABS pump and put black tape over the ABS bulb while the dash was apart a few years ago!
VSS was super easy to get to. Back, upper driver side of the transfer case. On mine it was the only sensor on the TC output, so it made it easy to figure out. I didn't have a 1" socket, but a crescent and a coupla smacks with a hammer had it right out.
Old Jul 18, 2016 | 05:22 PM
newguy's Avatar
vss has nothing to do with abs. 4 abs sensors communicate with each other as to speed
Old Jul 18, 2016 | 06:28 PM
I'll take your word for it. I thought I had seen the abs light mentioned along with vss problems. I don't know that much about abs systems. Heck, the Blazer is the only car I've had that's had abs, and it's been removed!
Old Jul 18, 2016 | 08:26 PM
Racer_X's Avatar
Racer_X is on a distinguished road
That's news to me. Do you have part numbers for the left rear and right rear wheel speed sensors? Any links to repair procedures to replace the left rear or right rear wheel speed sensors?
I'm pretty sure cleburne red is right on this one. The second generation Blazers (actually all second generation S/T series trucks with ABS) have a 3 channel ABS system. There are two front wheel speed sensors (integrated in the backing plates on 1996 and 1997 models, integrated in the hub/wheel bearing assemblies in the 1998 and later models) and the rear wheel speed is derived from the vehicle speed sensor, in the tail housing of the 2wd transmission, or in the back of the transfer case on the 4wd vehicles.
Old Jul 20, 2016 | 07:34 AM
Tajohns34's Avatar
You got lucky that it was you VSS. I had the same symptoms a few years ago and it turned out to be the wiring harness. Cost me almost $300 to have the Harness repaired.
S10BlazerFTW
Jun 16, 2013 03:35 PM
Charlz B.
Jan 4, 2010 09:03 AM
bigdawgz2006
Nov 21, 2009 02:44 PM
coupster
Jul 19, 2009 11:16 AM
Fenris
Sep 16, 2008 04:19 PM
