Trico Winter Wiper Blades
I recently picked up a couple Trico Winter Wiper Blades, however, it seems as if the passenger side blade doesn't cover as much surface area of the windshield as the driver's side. The passenger side kind of hangs off the side without touching the windshield...is this typical for this kind of blade? Any thoughts?
RE: Trico Winter Wiper Blades
It's not just that brand of blade. Mine does the same with other brands, also.
look closely at the new wiper blade the mounting point isnt always in the center if you happened to put it on upside down it will hang off turn it around and problem solved. Had this happen to me cause I was in a rush that'll learn me to hurry even on something as simple as a new wiper blade. Sometimes the stupidest things will bite you in the butt hopefully that's all your problem is.
Yah both my current Trico winter blades and my last Anco Winter blades hang off the edge. The Trico seems to be worse than the anco but then again I dont really need to look through that little part of the windshield.
THePaRaSiTE5771
04-03-2011 03:21 PM
