TURN SIGNAL BLINKING QUICKLY
Old Nov 20, 2008 | 09:33 PM
KHARDA's Avatar
KHARDA is an unknown quantity at this point
Default TURN SIGNAL BLINKING QUICKLY
1998 BLAZER AND SUDDENLY TURN SIGNAL BLINKING VERY FAST ON DRIVERS' SIDE BUT LIGHT NOT BLOWN OUT. DO I NED TO CHANGE A BULB? ANY HELP APPRECIATED
Old Nov 20, 2008 | 09:40 PM
Default RE: TURN SIGNAL BLINKING QUICKLY
You have a bulb out somewhere. Check front and rear.
Old Nov 20, 2008 | 09:42 PM
mudd4's Avatar
mudd4 is an unknown quantity at this point
From what I have found their is a bad bulb(blinker out). There is 2 flashers in the front and 1 in the back. If they are all working I would say either one of the bulbs is shorting or you have a short somewhere.
Old Nov 20, 2008 | 09:44 PM
KHARDA's Avatar
I PUT A NEW BULB IN THE FRONT ON DRIVERS SIDE AND IT DIDN'T FIX IT.THEN I PUT THE NEW BULB IN THE REAR AND IT DIDN'T FIX IT. WOULD I NEED TO TRY IT OUT ON THE PASSENGER SIDE? I WOULDN'T THINK SO. THANKS
Old Nov 20, 2008 | 09:49 PM
KHARDA's Avatar
YOU ARE SO RIGHT MUDD4 I HAVE ONE OF THE TWO FLASHERS ARE OUT. IT IS THE ONE ON THE SIDE BUT IT IS A AMBER COLOR AND ALL I AHVE IS A CLEAR BULB SO I WILL TRY THAT. THANKS
Old Nov 20, 2008 | 09:51 PM
mudd4's Avatar
No I would not think so. Did you try putting 2 new bulbs in?? If that doesn't work I would say that it is shorting out some where, or something else is wrong beyond my technical knowledge....
Old Nov 20, 2008 | 09:52 PM
KHARDA's Avatar
OH SORRY... THANKS TO YOU KYLE ALSO FOR THE HELP. I THOUGHT I REMEBERED FROM A LONG TIME AGO THAT A QUICK BLINKING LIKE THAT MEANT A BULB OUT BUT I DIDN'T KNOW TO LOOK FOR MORE THAN ONE LIGHT UP FRONT.
Old Nov 20, 2008 | 09:54 PM
mudd4's Avatar
yes there is 2 blinkers up front..... your welcome. Hope you get it fixed. Let us know what you find.
Ryan
Old Nov 20, 2008 | 10:02 PM
KHARDA's Avatar
WELL THE BLOWN AMBER BULB IS REAL TINY SO I HAVE TO GO BUY ONE TO REPLACE THAT ONE. SO I WILL CONTINUE THIS TOMORROW AFTER BUYING THE REPLACEMENT BULB. THANKS AGAIN
Old Nov 20, 2008 | 10:23 PM
95Blzr's Avatar
95Blzr is an unknown quantity at this point
When I have my right blinker on sometimes it speeds up blinking. Its not out but the speed changes randomly. Any ideas?
