turn signals.brake lights blowing fuses
Old Jul 18, 2008 | 09:04 PM
deltas69's Avatar
deltas69 is an unknown quantity at this point
Default turn signals.brake lights blowing fuses
for some unknown reason, wifes 96 blazer two door has started blowing the brake/haz fuse and t/s fuses..i work for AC/DELCO and replaced both flashers..still no cure..all fuses are proper amp and in proper place..nothing has been changed or altered to the wiring..just suddenly blown fuses..takes a while..usaly twenty/thirty minutes of driving/using them..then i have to replace the fuses..tailights are unaffected..all bulbs good, no corrosion in tailight sockets or damaged wireing..this has my ASE son and i stumped..any help much appreciated..thanks..pj in nashville
Old Mar 20, 2009 | 08:05 PM
ccvair's Avatar
ccvair is an unknown quantity at this point
any ideal ? Im having the same issue.
Old Mar 20, 2009 | 08:59 PM
This problem could be caused by an internal short in the multifunction switch.
Old Mar 20, 2009 | 09:25 PM
ccvair's Avatar
does a 89 have a multifunction switch?
Old Mar 20, 2009 | 10:04 PM
A 96 does. You are piggybacking off of the original thread. If you have an 89, you might want to post in the appropriate forum...
Richard Tucker
Aug 10, 2015 02:04 AM
gstxtt
Dec 5, 2013 02:56 PM
radiorara
Apr 14, 2011 03:04 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
abadinalbany
Apr 7, 2010 06:07 AM
