Turning problem in 4WD mode
Old 12-20-2006 | 03:51 PM
Marcin's Avatar
Marcin is an unknown quantity at this point
Default Turning problem in 4WD mode
Hi
I have problem (or maybe it is not a problem but I do not know) turning car with 4Hi or 4Lo switched on. Turning4WD car seems to be a little bit stunted - as somebody pressed a little brake pedal. And I can feel a kind of resistance every wheel rotation (or maybe very half of full rotation). What could be a problem?
I can say I have front tires new and rear rather poor - could it cause the problem?
Regards, Marcin
Old 12-20-2006 | 04:23 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
Default RE: Turning problem in 4WD mode
Are you turning it on dry pavement?
If so, that's the reason it feels like that. It's normal, since the front tires are trying to pull against the pavement along with the rear tires. It's not all that good for your truck to run it in 4x4 on dry pavement.
Old 12-20-2006 | 05:12 PM
Marcin's Avatar
It was not too dry pavement. It was raining and I decided to check 4WD mode becouse next two weeks in Poland heavy snow is expected.
Marcin
Old 12-20-2006 | 05:14 PM
Jigg's Avatar
Even the rain doesn't really make for enough give, that's pretty normal for operating in 4x4 on tight surfaces.
Old 12-20-2006 | 05:29 PM
LORCLAS's Avatar
LORCLAS is an unknown quantity at this point
It's called "Tire Scrub" or "Crow Hopping". 4x4's don't have a front differential so bothfront wheels have to turn at the same speed. When turning, the inside wheels are turning in a tighter circle then the outside wheels. A differential solves the problem by rotating the inside and outside wheels at different speeds.
When doing tight turning manauvers like parking or U-turns, disengage your 4x4 system. That's what I used to do with my 4x4 Sport Trac.
Old 12-20-2006 | 06:38 PM
Marcin's Avatar
Are you sure? I know that there is no central differential but in manual theysay that front differentail capacity is 1,2 litre of fluidso I guess there is front differential
Marcin
Old 12-20-2006 | 06:39 PM
Jigg's Avatar
There is definitely a front differential.
Old 12-21-2006 | 12:36 AM
LORCLAS's Avatar
My bad. Yes there is a front differential, but I don't think it works like a rear with clutch packs, etc. I think it just locks the axles together. I had a really good 4x4/AWD Power Point from a Ford engineer, but I can't find it now.
<---- not a 4x4 expert.
Old 12-21-2006 | 10:50 AM
Actually, the hop is caused by the fact that there is no center differential. Even with 2 open diffs in the front and back, you are still requiring 2 wheels to turn at the exact same rate. In a turn, no 2 wheels will travel the same path (ok so it is possible) and as such, they all are turning at a different rate. With a 4wd vehicle, this will result in one of those 2 wheels (the one with less traction) to slip in an attempt to maintain the same number of rotations as the other.
Here's an illustration:Different Wheel Speeds in Turns - 4x4abc.com
So yeah, it is completely normal.
Old 12-21-2006 | 01:42 PM
LORCLAS's Avatar
No center differential, that's what I was thinking of. Doh.
Thanks for the explination.
