Turning signal click after hazard replacement
Old Dec 31, 2009 | 08:28 AM
nnnon632's Avatar
nnnon632 is an unknown quantity at this point
Default Turning signal click after hazard replacement
Hey everyone, so i had the annoying relay click from my turning signals without doing anything. I originally thought it could have been the relay, it wasn't. So i read and some guys pointed out that the hazard switch could have been a failure. Since it was cheap I went for it. With both of those parts replaced it still clicks. But now its only when I don't apply pressure to the brake. Before it did it no matter what I did. Anyone have any idea if there is something wrong with the electronics with the brake pedal, such as a short or a switch that failed or the whole multifunction switch needs replacement. Also is there any way to troubleshoot these things before I buy anything. I did the small diagnostic for the hazard switch with similar answers to what was posted, but either I was wrong or two things failed at once. Thanks for the help.
Frank
Old Dec 31, 2009 | 09:05 AM
If replacing the hazard switch alone did not stop the relay from clicking, the problem is deeper into the multifunction switch. Common problem.
Old Dec 31, 2009 | 04:40 PM
nnnon632's Avatar
Im probably going to try to take the switch apart hopefully find something. Do you think its worth it, or a waste of my time, and even if i fix it, it wont last long?
White Locust
Feb 13, 2014 10:58 AM
clbychil
Apr 12, 2011 11:20 PM
davedidit
Dec 12, 2010 06:54 PM
boomb1
Mar 30, 2008 12:42 PM
[[B3k@h]]
Jan 1, 2008 12:32 PM
