Turns over, no start
#21
no, we are not the same person. My Blazer finally broke down for good with the issue I originally posted. I ruled out the ignition switch. It goes to the shop tomorrow. I planned to update once it's fixed (and will) and discovered the thread was hijacked. Oh, well, lol.
I was getting so confused. Since it finally went to a hard fail were you able to find out if it was spark or fuel or did you just decide to let the shop handle the whole problem?
George
#22
I should know tomorrow what the problem is. Hoping for something cheap and easy to fix. I need my ride back, lol.
I'll update the thread when I know more so it can serve as future reference for others. The video on testing the ignition switch is handy, though, as it literally sounds exactly as mine does. The only difference is that whatever's going on with mine began as intermittent failure. I've never known a fuel pump or computer module to fail in this manner so I'm hoping it's a sensor or clogged fuel filter. Something, as I said, cheap and easy to fix.
#24
So, my mechanic finally got to my Blazer today. He hopped in and turned the key to see what it's doing......and it started right up. Smh.
We're both leaning toward fuel. I'm mostly leaning toward crap in the tank or filter intermittently blocking the fuel pump screen or filter outlet. This might explain why it starts after sitting (loss of pressure allows the obstruction to fall out of the way or, in the most recent instance, the vehicle being towed "washing" the obstruction out of the way with the movement).
I also apparently have a fuel leak somewhere. Not excessive but it needs to be fixed. So I've told him go ahead and replace the fuel pump, fuel filter and fix the leak. I've never known a fuel pump to fail in this manner ( I've been driving professionally for over 30 years and haven't paid more than $1500 for a personal vehicle in that same time period) but the professional says he has.
if he finds something during repair that seems definitive, I'll update. If it breaks down again after repair, I'll update. Otherwise, anyone reading this can assume we found the problem.
#25
Here is a diagnostic work flow which may come in handy if you still have the problem. Travel with a fuel pressure gauge and spark tester to catch the problem when it happens. Good luck:
https://blazerforum.com/forum/2nd-ge...rticle-103750/
George
George
#26
George
George
#27
#28
The way to solve this problem is to eliminate most possibilities and pursue the possibilities that come up as issues, starting at the top:
1) Spark - -you have confirmed spark so all kinds of issues are off the table including the ignition switch starter and ignition voltage functions
2) You have adequate fuel pressure (I think) so a bunch of stuff is off the table, fuel pump, regulator, leaking injectors, ...
3) Next up would be fuel injector control pulses. I suspect this to be your problem. If i am wrong then its on to ...
4) Bad gas
4) Timing
5) Mechanical problems
George
#30
Guessing from battery being so low, now when I try start it it dont even try it just clicks. But all dash lights come on like normal... but again will get charger hooked up to it and will test battery to see if it's still good.
