UJoint Caps Bolts
Old May 13, 2012 | 05:12 PM
postal0dude's Avatar
postal0dude is on a distinguished road
Default UJoint Caps Bolts
Well I wanted to remove the encoder motor on the transfer case of my 2000 blazer LT and when I went to remove the 4 (11mm) bolts of the UJoint, they were all rounded to the point where I can't put enough torque on them for removal..
Is there a place where I can buy those bolts, and what specs are they? thread and length?
Thanks!
Btw, removing them with this kind of kit will work you think?? 10 pc. Damaged Bolt/Nut Remover Set, Low Profile Bolt-Out- Craftsman-Tools-Auto & Mechanics Tools-Taps & Dies
Or should I cut the head of the bolts and unscrew the bolt with a vise grip?
Also, should I apply some heat before working on those, looks like they were over torqued or something.. And yes I chewed them a bit trying to work them out with no luck..
Old May 13, 2012 | 05:21 PM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
A little heat wouldn't hurt. I would say that extractor kit would do the job well. I have a similar one at home and worked great the time I needed it. I'd ask GM the pitch and grade of the retaining bolt, and find some at canadian tire for pennies ;0
-OSS
Old May 13, 2012 | 05:23 PM
Thanks, I'll give it a try..
postal0dude
May 19, 2012 07:30 PM
blazinloud
Nov 6, 2010 09:10 PM
bragdog
Feb 5, 2008 01:49 AM
bragdog
Jan 14, 2008 02:28 PM
93chevyblazer
Tires and Wheels
Apr 2, 2007 03:14 AM
