Underhood fuse block
Old May 6, 2013 | 09:42 AM
step66's Avatar
Default Underhood fuse block
Hey! I am trouble shooting a non functioning center mount stop lamp.In searching the forum,threads relate to a relay in the underhood fuse block.Well,I must be daft as I cant locate any such animal.The only major electrical unit I see is on top of the passenger side fenderwell above the coolant expansion tank. Isn't this the computer? There are 3 relays in the glove box but none are marked. This is a 97 by the way. Appreciate any input.
Old May 6, 2013 | 09:58 AM
Blues15's Avatar
Blues15 is on a distinguished road
Guess your talking about the LED third brake light? Those go out sometime, but if your not getting fire to the light the fuse/relay block under the hood is located on the driver side by the washer fluid tank. Not sure if that's where the relay/fuse is at tho. Might check the driver side fuse block inside the vehicle. Hope i helped you.
Old May 6, 2013 | 12:25 PM
step66's Avatar
Yo! There is no fuse/relay block located in that position! The only thing near the w/w tank is the ABS module. There are 3 relays mounted on the firewall above the distributor however...none of these are marked as to their function either.
mh99506
Mar 7, 2022 12:45 AM
Joann
Oct 14, 2013 10:33 AM
lombard
Dec 27, 2011 03:54 PM
2001Jimmypwner
Feb 2, 2010 01:54 PM
lil_blazin
May 10, 2009 05:20 PM
