Unidentified miss
![Red face](https://blazerforum.com/forum/images/icons/icon11.gif)
98 blazer, has 191,500 miles, when i got it, the owner said it needed an O2 sensor because it was running rich. It idled rough but was fine while driving. So I got a whole tune up for it and 2 sensors. After completing all that work, it starts better but still misses at idle. I'll double check that the wires are seated on the plugs, but after that, I'm kind of at a loss. Any ideas?
Get some carb and injector cleaner and see if it makes a difference, could be the spider injector sticking... hard to tell without pressure testing or anything else... small things like air filter and fuel filter are easily forgotten and tend to reduce flow...
Misfires can be a challenging journey, there are many potential causes. Some approaches:
Fuel -
You can check fuel pressure per the sticky at the top of this forum
You can run a cleaner through the system like Seafoam to see if it helps as Don suggested
Some swap/upgrade the "fuel injectors" just because but I'm not a fan of parts swapping without a smoking gun
The definitive tests for bad injectors is looking at scope traces (pintle humps, etc) and/or doing an injector balance test
Ignition -
Lots of guys replace the ignition tune up parts if they are due anyhow but it sounds like you did that. Did you use AC Delco parts?
You can monitor misfires with live scanner data to see if its a specific cylinder or random
Again the definitive test here are scope traces (voltage levels, ringing, etc)
A water spray bottle at night can help identify leakage
A drop cylinder test can find a bad cylinder
Compression -
Testing all cylinders for compression can locate the problem cylinder if there is one
Vacuum/air leaks -
Checking vacuum hoses and the air intake connections can clear up problems.
A water spray bottle can help here too
Fuel trims -
Another scanner data lead. Many sources of misfires can be indicated with this test - vacuum leaks, MAF sensors, O2 semsors, air intake leaks, fuel pressure, bad injectors, etc. The data can narrow down the search.
CMP retard -
Another scanner lead that can be way out of spec and cause problems
O2 sensor live data -
Helps determine if the sensors are getting sluggish or have failed
Scan for any other codes -
Can help pinpoint problem areas
Other possibilities -
Dirty EGR
Dirty throttle body
Fuel filter
Exhaust restriction
Bad coil or ICM
Bad ECT sensor
Bad MAF sensor
Bad MAP sensor
Worn distributor
That's probably enough for one post. Let us know if you want to pursue any of these.
George
Fuel -
Ignition -
Compression -
Vacuum/air leaks -
Fuel trims -
CMP retard -
Dirty EGR
Dirty throttle body
Fuel filter
Exhaust restriction
Bad coil or ICM
Bad ECT sensor
Bad MAF sensor
Bad MAP sensor
Worn distributor
George
Thanks for the response. I'm thinking it's vacuum lines (mine are HORRIBLE), clogged cat, or a dirty MAF. If it still is missing after that, then I'll move onto the pressure tests, etc. It runs ok while driving but at idle is when you notice. I got vacuum lines today, hopefully I'll be able to change them before work tomorrow, but it looks like I'll be shoveling. I'll keep ya updated. Happy Turkey Day!
I did some research and came to the conclusion that it has to be the fuel pressure regulator. I found several videos on YouTube that describe the very same problems I'm having and how it causes it. So I ordered a new regulator and parked it for the time being. One reason is because a ton of gas has gotten into the oil and I don't want to lock the engine up, the other reason is because I used a 1/2 tank of gas for 120 miles. So after I change it out I'll let you know if that was the fix. I'm hoping it doesn't come down to ripping the heads off. 😂
justinh4578
103
11-04-2011 05:12 AM
blazeofglory
86
05-22-2011 07:49 PM
