universals
universals
on a 1999 blazer 4wd ,on the rear drive shaft is the front same as the back universal ?
you can check autozone.com and see if the part numbers are the same. they are probably the same size but i think the front uses 4 outer clips and the rear uses 2 outters then 2 inners where it goes into the axle
