Urgent...problem with fuel broken return line
Old Mar 24, 2013 | 12:00 PM
AbbyNormal's Avatar
AbbyNormal is on a distinguished road
Angry Urgent...problem with fuel broken return line
Hello,
I need help urgently!! I was installing a fuel pump into a '98 Jimmy when I needed to shift the tank slightly. All was well until I heard a pop and then saw that the plastic return line on the pump snapped off near the hub.
Now, I am stuck.. Does anyone know how I could fix this??? Any tricks or glues??
Dan
Old Mar 24, 2013 | 12:22 PM
puzzled's Avatar
puzzled is an unknown quantity at this point
souns ilke you need anothr pump or if this was a repair and replace you can swap out with the old pump it is possible ive done it just be carefull
Old Mar 24, 2013 | 12:31 PM
cw801971's Avatar
cw801971 is on a distinguished road
Do you have enough sticking out of the hub to clamp a small piece of rubber hose onto? If so you could patch it with that.
Old Mar 24, 2013 | 02:07 PM
Spree's Avatar
Spree is on a distinguished road
My vote is also another new pump.
Old Mar 24, 2013 | 04:39 PM
AbbyNormal's Avatar
Is it possible that I can glue it back on then put a hose an clamp it together. What is the return pressure on that line? Do you think that this type of fix would work and be able to accommodate the pressure?
Old Mar 24, 2013 | 06:24 PM
BigBlackBlazer's Avatar
BigBlackBlazer is on a distinguished road
gasoline is a great solvent, it may dissolve any glue it comes in contact with
Old Mar 24, 2013 | 10:23 PM
cleburne red's Avatar
Did the exact same thing on my sis in laws Chrysler mini van. I was replacing the fuel filter that they decided to mount on top of the fuel pump with some weird plastic snap fittings. I broke the return line right off! $200 later, she has a brand new fuel pump. I tried all sorts of fixes I could think of, but nothing worked.
The real pisser? Nothing even wrong with the filter, or the plug wires I replaced trying to track down a misfire under-load. I had replaced her spark plugs the day before, and I had cracked one and it was grounding out on the manifold. I attached it to my toolbox. I tell people it's a $250 spark plug. Reminds me to check everything before throwing money at problems...
Old Mar 25, 2013 | 08:27 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
glue wont work, the gas will just eat it. The return line isnt very pressurized when compared to the inlet line, if there is enough plastic to attach the hose to with a hose clamp it could work. But you need a new sending unit assembly minus the pump, and use the existing pump to save some $$$.
RCarp48
Sep 11, 2012 01:21 PM
PayneSource
Dec 21, 2011 01:28 AM
hevi99
Aug 7, 2011 09:10 PM
justin1795
16
Apr 25, 2009 09:25 AM
vagnozzi
Jul 5, 2007 02:02 AM
