Vaccum Diagram for 2003 Chevy Blazer
Old 04-28-2021, 02:14 PM
Brynja's Avatar
Brynja is on a distinguished road
Default Vaccum Diagram for 2003 Chevy Blazer
Does anyone have a vaccum Diagram that includes the line that comes out of the Driverside fender?
Old 05-01-2021, 02:40 AM
error_401 is on a distinguished road
Try a search in the forum and have a look at the DIY sections and the tech articles.
Old 05-01-2021, 09:55 AM
LesMyer's Avatar
LesMyer will become famous soon enough
There is a vacuum reserve tank inside the fender that line hooks to. This tees with a plastic line that goes through the firewall under the brake booster, and through a check valve to vacuum source on the intake. Somewhere in this same immediate area this also splits off to be the vacuum supply to lock the front axle into 4WD operation. Depending which year and type of transfer case you have, this goes either to a valve on the transfer case or to an electronic valve on the firewall above the distributor.
Old 05-09-2021, 08:48 AM
puttster's Avatar
puttster will become famous soon enough
Hoses are 7/32 and 5/32. In a 2wd their only function is to open the doors for the HVAC. IMO check valve is not vital. If the hoses are open there will likely be a vacuum leak to the intake. Here are some pics from a 2wd: https://blazerforum.com/forum/2nd-ge...d-hose-102386/
1sttimejimmyowner
07-24-2015 06:38 AM
user_13120
10-29-2013 03:35 PM
sportjunkee
01-01-2013 03:02 PM
guitarranger11
10-03-2012 09:33 PM
rob_Israel
11-12-2011 10:21 AM
Quick Reply: Vaccum Diagram for 2003 Chevy Blazer
