Vacuum Line Chart for 2nd Gen ?
Old Nov 16, 2013 | 11:32 AM
DouglasWillard19's Avatar
DouglasWillard19 is on a distinguished road
Originally Posted by WalkGood
What if the ball has a crack/leak? How do you replace it?
I believe you'd have to pull the fender off to get to it. Not sure if it can be pulled off without moving the abs unit though.
Old Nov 16, 2013 | 07:32 PM
spittybays
Guest
Posts: n/a
Don't stress about that, mine is on the hood. You can mount a new one anyplace you can find space. It's just a reservoir to hold - pressure.
It could be a one quart mason jar with a nipple on the lid.
Old Nov 17, 2013 | 10:36 AM
WalkGood's Avatar
WalkGood is on a distinguished road
Pressure? Or vacuum?
Old Nov 17, 2013 | 12:09 PM
Katmandu's Avatar
Katmandu is on a distinguished road
Question
Originally Posted by DouglasWillard19
you won't be able to use 4wd and your heat/ac directional controls won't work.
Actually, my vacuum line to that little nipple is blocked off right now with a screw in it. So I have to vacuum reservoir in use and both my 4x4 and my heater blend door are working great.
So what is the actual purpose of this reservoir then ?
Old Nov 18, 2013 | 09:12 AM
WalkGood's Avatar
If this is a brake vacuum reservoir/booster then :
The purpose of the reservoir is to make vacuum available for a short time to the booster unit should the vehicle have to stop quickly with a stalled engine. A check valve in the reservoir maintains a uniform vacuum within the system should engine vacuum drop off. This check valve prevents vacuum from bleeding back to the intake manifold when manifold vacuum is less than the vacuum in the reservoir.
Stolen from :====> Vacuum Boosters - Continued
Sisk
Lifting Tech
Feb 15, 2010 07:11 PM
NC93BLAZERLT
Nov 23, 2009 09:12 AM
old skool luvr
Nov 10, 2009 09:20 PM
94blueknight
Apr 6, 2008 08:34 PM
TripleBlackBlazer
Apr 3, 2008 06:48 PM
