Very Poor Radio Reception
Old Aug 24, 2007 | 03:24 PM
tyson0016's Avatar
tyson0016 is an unknown quantity at this point
Default Very Poor Radio Reception
I've got a '99 Blazer, all stock, that has terrible radio reception. At first I thought maybe there was a lose connection in the antenna, but removing the external antenna just makes it worse. (Which would seem to indicate there is in fact a connection.)
Should I pull the unit out of the dash to check connections, and if so, what should I be looking for? OR is there something else that could be causing this?
Basically, I can only pick up 3 or 4 FM stations within about a 45 mile radius. Even the local stations occasionally have static or just start to fade a little.
Old Aug 24, 2007 | 03:35 PM
hillbillyinOhio's Avatar
Default RE: Very Poor Radio Reception
some factory radios just lose reception for some reason. you could pull the radio out and make sure that the antenna isnt grounding out to something. you can also pick up an FM booster at most parts stores for about 15 bucks or so.
Old Aug 24, 2007 | 04:29 PM
tyson0016's Avatar
Ok thanks. That at least gives me some idea.
klote82
Apr 27, 2012 08:22 PM
THePaRaSiTE5771
Mar 15, 2012 05:43 PM
BlackMatter
Feb 16, 2012 10:27 PM
cochran07
Jan 19, 2011 01:33 AM
Dabber
Sep 14, 2006 09:10 PM
