Vibration in 4wd only?
Old Feb 3, 2009 | 12:51 PM
kgkern01's Avatar
kgkern01 is an unknown quantity at this point
Default Vibration in 4wd only?
So the other day I parked in some unlevel ice/snow driving in 4wd HI and a chunk of ice popped my back right tire. So I jack it up, put the spare on, and when I leave, all of a sudden I am getting a vibration in the front right and it sounds almost like offroad tires do on the road, that low roaring sound. If I switch it back to 2wd, it sometimes takes little longer to shift back to 2wd, but the vibration and sound go away. If I switch to Auto 4wd or 4wd HI the vibration problem comes back. What could be causing this, why, and how do I fix it?
Old Feb 3, 2009 | 01:18 PM
bammontana's Avatar
bammontana has a little shameless behavior in the past
Default RE: Vibration in 4wd only?
Is the spare the same tire size as the rest of your tires. I know that if you have different size tires on your truck and are in 4x4 it wont like it.
Old Feb 3, 2009 | 02:33 PM
WolfPack's Avatar
x2.
alot of blazers have factory 235/70/15s, but when people replace tires, they put on 235/75/15s. I know my blazer still had a 235/70 spare when I replaced my tires from 75s to 30x10.50s.
thennnnn complicate that with usual under-inflated spares which further throw off the drive line...
Old Feb 3, 2009 | 05:42 PM
kgkern01's Avatar
Yeah the spare is 235/70R15 and the other 3 tires are 235/75R15. So are you guys saying that is the only thing that would cause the 4wd system to act like that?
Old Feb 3, 2009 | 06:15 PM
WolfPack's Avatar
Not the only...but...lemme reference scrubs:
'if you hear the sound of hooves running towards you, go ahead and think horse, not zebra'
Old Feb 4, 2009 | 07:03 AM
You cannot mismatch tires like that and expect everything to work properly. There is 1" difference in overall diameter between a 235/70R15 and a 235/75R15 tire. That is a LOT, especially on a vehicle with no center differential.
bobtrub
Dec 8, 2011 08:47 AM
ubrainium
Mar 9, 2011 01:25 PM
scrawford
Dec 29, 2009 05:51 AM
matthew116
Aug 3, 2009 06:20 PM
Kendo
13
May 22, 2009 11:44 AM
