Vibration over 50mph
Old Jan 30, 2011 | 12:10 PM
Francis_QC's Avatar
Francis_QC is on a distinguished road
Default Vibration over 50mph
I bought a 98 blazer 2door a month ago, and on my first drive with it there was a godd vibration over 50mph. I've balanced the tires (no force balance, the guy didnt have the machine), but no change, still vibrating. I've look up the u-joint, and they're all perfect.
Today i've put two jack stand under the rear diff , just high enough so the wheels does'nt touch the ground and make it spin up too 70mph. There was no vibration at all!
SO i'm lost there, someone got answer?
Old Jan 30, 2011 | 12:43 PM
AJBert's Avatar
Could be the alignment is out a tad bit. Trying to track down resonate vibration can drive a body insane sometimes. I've got the same thing with mine, though at 65-70 mph. I'll be getting all the tires balanced tomorrow and hopefully that takes care of it. If not, alignment. If not, I'll pull the drive shaft and check the balance on it checked. If not, I'll be on here asking questions.
Old Jan 30, 2011 | 01:24 PM
dobyken's Avatar
dobyken is on a distinguished road
Did you check all your ball joints, tie rod ends, and idler arm?
Old Jan 31, 2011 | 07:12 AM
Francis_QC's Avatar
All seems good.
Old Jan 31, 2011 | 10:52 AM
Tommy G's Avatar
Tommy G is on a distinguished road
Check your front driveshaft. There is a CV joint on it that can go bad. Just put it in park, crawl underneath and see it it has any lateral (up/down/left/right) play near the transfer case. When mine was bad, I felt a vibration under the floor, drivers side. Also my front hubs were staying engaged, causing the front driveshaft to be driven by the wheels all the time, and causing the vibration even when in 2wd.
Old Jan 31, 2011 | 03:00 PM
Francis_QC's Avatar
Yup I just receive the same message on another board, I'm gonna chek this out tonight after work!
Old Jan 31, 2011 | 08:58 PM
Francis_QC's Avatar
So I look up my front d shaft and it doesnt disengage, so front dshaft coulb be the problem. But it's minus 20 degree celcius outside here, so i'll wait a day or two! lol
Old Feb 2, 2011 | 02:14 PM
AJBert's Avatar
Just thought I'd follow up. Simple balance of all four tires cleared up my vibration.
Old Feb 3, 2011 | 10:19 AM
Francis_QC's Avatar
Your lucky, still working on mine! lol
das96blazer
Jan 23, 2012 08:48 PM
l67coooled
Dec 20, 2011 07:15 PM
jeffkoski
Apr 30, 2010 06:26 AM
dffraz
Aug 25, 2008 01:14 PM
mr_seanathan
Aug 29, 2006 10:41 AM
