Visor Broken Lights Causing other Problems
Old Jan 2, 2010 | 09:10 PM
twhite0218's Avatar
twhite0218 is on a distinguished road
Default Visor Broken Lights Causing other Problems
I have a 2001 Blazer LT. The lights on my sunvisor burned out because the cover broke off. When I tried removing the bulbs to replace them, they broke. This caused my three overhead lights to also go off. I have tried unplugging the lighting unit in the visor, replacing the bulbs in the visor lighting unit, and replacing the fuse, but the none of these corrected the problem. Any suggestions?
Old Jan 2, 2010 | 09:41 PM
AJBert's Avatar
This is why I didn't pull the lights out because they are damn near impossible to get out. I almost went with just crushing them, glad I didn't. Two have burnt out and I'll just wait for the other two to do the same.
As to helping you, have you checked to see if the other bulbs did blow when you did this? Seems odd that all three would go at the same time without blowing the fuse but you said you already replaced the fuse. Otherwise, I'm at a loss.
Old Jan 3, 2010 | 06:50 PM
twhite0218's Avatar
Default Thanks!
I will try to replace the other bulbs. The map bulbs were almost impossible to get out too! Ridiculous...I'll let you know if this works.
Old Jan 3, 2010 | 07:14 PM
JST4SHO's Avatar
JST4SHO is an unknown quantity at this point
Get a new mirror/cover unit from a raggy visor.
Old Oct 12, 2010 | 03:01 AM
chevyblazer's Avatar
chevyblazer is an unknown quantity at this point
Hi guys, my sunvisor bulb burnt out too, and i wanna fix it by myself, coz no place to order from....! gmpartsdirect says the parts discontinued!!! However i am not sure what the bulb i need buy, the KW???
Any tip will be very much appreciated! thanx in advance!
Enjoy the lighted visor mirror!!!
Old Oct 12, 2010 | 12:25 PM
g_mike's Avatar
g_mike is on a distinguished road
my visors are somewhat broken, the lights stay on constant because the flap that covers the mirrors is broken, so im just unplugging them and leaving them like that.
i did see a new mirror assembly on ebay.
http://cgi.ebay.com/ebaymotors/94-04...Q5fAccessories
http://shop.ebay.com/?_from=R40&_trk...All-Categories
chevyracingfan23
Jul 11, 2012 01:11 AM
kmartin
Jul 26, 2011 04:05 PM
blazen99
Oct 20, 2009 12:38 AM
Sterling
Mar 17, 2008 03:58 PM
a_tack
Nov 29, 2006 12:16 AM
