voltage drop
Old Nov 16, 2010 | 07:34 PM
kmrwildcat's Avatar
kmrwildcat is on a distinguished road
Default voltage drop
i have a 2000 blazer that has a voltage drop. I thought i found the issue with the brake switch but to no evail. I have pulled all fuses with a tester in place and the light doesnt go out. I need help what should i go after now.
Old Nov 16, 2010 | 07:42 PM
69chevelle's Avatar
69chevelle is on a distinguished road
voltage drops to what? from what? when? why did you think it was your brake switch? what light?
Old Nov 16, 2010 | 07:50 PM
kmrwildcat's Avatar
I used a test light on the system. I disconnected the positive side hooked the tester to the cable and probed the battery positive side. When i started tracing down a voltage drop i was told by pulling all the fuses 1 at a time the light will go out on the tester when u find the short. It never did. When i messed with the brake switch the light would get brighter when the pedal was pushed. If this thing sits for more tha 6 hours my voltage drops around 3.5 volts. It has a new alternator and battery all from GM.When the system (charging) is tested it shows the voltage drop.
Old Nov 16, 2010 | 08:02 PM
69chevelle's Avatar
never heard that technique, but I'm not an electrition or mechanic.. you remembered the main fuses under the hood, right?
Old Nov 16, 2010 | 08:04 PM
kmrwildcat's Avatar
Yes i pulled everyone that would come out. Including the door panel as well.
Old Nov 16, 2010 | 08:08 PM
bandidolenny's Avatar
I would find someone with a Tech2 or equivlent scanner and pay them an hour labor to diagnose the issue. Sounds like you may have a Gem module acting up but it is hard to say... good luck.
Old Nov 16, 2010 | 08:10 PM
kmrwildcat's Avatar
What is approx cost of a module. Are they easy to replace.
Old Nov 16, 2010 | 08:19 PM
There is more than one... but that may not even be the problem. Hence the "TECH2" scanner. Not just a regular scan tool.
Old Nov 17, 2010 | 11:23 AM
What is the actual amperage draw?
Old Nov 17, 2010 | 03:47 PM
kmrwildcat's Avatar
I do not know the exact amp draw. I am loosing voltage to the tune of 3.5 volts over an 8 hour period. I'm not sure what amp rating is on the battery if i did i could calculate the draw for an approximate amp loss.
