Wants to stall under throttle at first start up
Old Oct 20, 2018 | 09:26 AM
  #21
Rusty Nuts's Avatar
Delco and Delphi seem to be the only reliable pump assemblies. Everything else lasts about a year. If it's been replaced already then the plugs were re-wired as well. I'd unwrap the tape and double check the work.
Old Oct 20, 2018 | 09:32 AM
  #22
ajfetterman's Avatar
ajfetterman is on a distinguished road
This pump has been in a week. I will check the splices again on the plug. If they check out, I guess that only points to the pump...again?
Old Oct 20, 2018 | 09:35 AM
  #23
Rusty Nuts's Avatar
What brand pump assembly did you get? Whoever sold it to you should stand behind it. If it's not Delco or Delpi get a refund. It matters.
Old Oct 20, 2018 | 09:37 AM
  #24
It’s a rockauto special. Brute power.
Old Oct 20, 2018 | 09:41 AM
  #25
Rusty Nuts's Avatar
It's probably junk. Did the pressure reach 73-108 psi at the filter?
Old Oct 20, 2018 | 09:56 AM
  #26
Rewired. No help. So, I got hosed on this pump and need a Delco?
Old Oct 20, 2018 | 10:00 AM
  #27
Rusty Nuts's Avatar
I bought a delphi because it was a little cheaper 2 years ago. Night and day difference. Delco cap and rotors don't burn up like everthing else either. Tell your son to smile, we're getting there.
Old Oct 20, 2018 | 10:07 AM
  #28
Thank you for your help guys!
I will get another new pump on order and see how it goes.
Old Oct 20, 2018 | 10:24 AM
  #29
Rusty Nuts's Avatar
For the sake of being thorough, check the resistance from the grounds on the plugs to chassis ground. There should be 5 ohms or less.
Old Oct 20, 2018 | 10:25 AM
  #30
GeorgeLG's Avatar
Delphi and delco have been the reliable brands for years. I have 100,000 miles on a Delphi BUT a recent thread here is about a guy eating through Delphi pumps and not finding joy until he tried AC Delco. A bad batch? Dunno. Try to stick with AC Delco. I like and use Rock Auto and have found lifetime warranty house brands good in other areas (ex: Bosch pumps dying in Mercedes, good results with auto parts warehouse lifetime warranty). In this case however Rusty is right, your house brand pump is propbably trash.
George
