water on floor board
Old Feb 13, 2008 | 12:57 PM
jon66's Avatar
jon66 is an unknown quantity at this point
Default water on floor board
o ok guys maybe you can help?
I am getting water on the drivers side floor board of my truck.
I have checked the windows the sunroof and still cant find where it is coming from.
it seems like it is dripping for in side somewhere and falling by the base of the gas pedal .
dose any body have a clue of where it is coming from.
I have run water on the door the roof ,window and can not find leek .
I don't know what else to check.
Old Feb 13, 2008 | 01:03 PM
cliro's Avatar
cliro is an unknown quantity at this point
Default RE: water on floor board
does it smell like antifreeze.
Old Feb 13, 2008 | 01:04 PM
TripleBlackBlazer's Avatar
I was thinking the same thing but I thought failed heater cores usually drip on the passenger's side? How's your coolant level and/or temperature gauge?
Old Feb 13, 2008 | 01:16 PM
cliro's Avatar
you by chance arent walkin threw the snow are you, lol.
jon66's Avatar
on it dose not smell like antifreeze.
everything is good. I only noticed it becouse it had rained a lot and the follr was wet.
I don't use the truck that mush I only use it on weekends
*Combining consecutive posts
no snow in texas
Please use the edit function if no one has posted since your last entry, thank you. TBB
Old Feb 13, 2008 | 01:17 PM
jon66's Avatar
on snow in texas
Old Feb 13, 2008 | 03:38 PM
chevcamls1's Avatar
chevcamls1 is an unknown quantity at this point
i have the same problem is not the heater core but am pretty sure is either the door weatherstrip or the rubber that goes from the door to the frame that covers all the wire
Old Feb 14, 2008 | 10:40 AM
garry2000blazer's Avatar
garry2000blazer is an unknown quantity at this point
If you're sure it's not a window or door seal, it couldbe following a wire, cable, or vacuum hose through the firewall from underneath the hood.
Old Feb 14, 2008 | 09:39 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
Ok....I am an expert on leaky blazers here...I had a passender rear floor leak for like 2 years....check the UNDERSIDE of the vehicle..I ended up finding a big gap underneath ...filled it up with caulk....no more leaks!
Old Feb 15, 2008 | 03:40 PM
thegr81's Avatar
I second paddle_grl check under the truck, there is plugs in the floor if one is missing then thats were water is coming in from!!
