Water rushing sound behind dash
Old Dec 6, 2011 | 08:50 PM
ABSLT's Avatar
ABSLT is on a distinguished road
Default Water rushing sound behind dash
So almost every time i take off from a stop i can hear the water rushing through the core. The core in about a year old, it doesnt leak, no coolant loss, no odor, no steam, and no overheating. I have tried burping the system by getting the front right side higher then the rest of the car, but still does this. So is this still air in the system i am hearing? or something else?
Old Dec 6, 2011 | 08:54 PM
chris015's Avatar
usually a sign of low coolant in the core. If the level is fine,id disconnect a hose at the core and pour some water in it until it overfills then reconnect it. See if that might take care of it. I know that it cycles through,but maybe it'll help purge any air in the system
Old Dec 6, 2011 | 08:55 PM
Xtreme 01's Avatar
Xtreme 01 is on a distinguished road
Man my blazer does the same thing! The core was replaced in 2004 and have no problems like you, but I hear the water rushing around too all the time.
Old Dec 6, 2011 | 08:59 PM
Mike98Blazer's Avatar
Mine does the same thing, no air in the system, and factory core. IDK i just ignore it lol
Old Dec 6, 2011 | 09:01 PM
ABSLT's Avatar
Ill give that a try, hope it works, ill post back with my results. Thanks
Old Dec 6, 2011 | 09:04 PM
ABSLT's Avatar
Lol i can but its my wife and shes driving me nuts about it, It didnt start doing it till core replacement so theres gotta be a way to fix it
Old Dec 6, 2011 | 09:07 PM
There's probably a small air bubble in there. Mine too more than likely but honestly it's not enough to overheat the engine so it doesn't bother me lol.
As for the wife tell her to turn up the radio
Old Dec 7, 2011 | 09:50 AM
Longer02's Avatar
Longer02 is an unknown quantity at this point
Mine does the same thing. My core is leaking however.
Old Dec 7, 2011 | 12:34 PM
warthogdriver's Avatar
i have had this battle for years...have won only one time.
i drove passenger front over curb to lift it, then ran it to operating temp and fill as you go...you should see some bubbles come out...and you will lose coolant so have some extra...i consider this problem my nemisis...i had it fixed then did intake and battled it then hose went so i am at it again...i HATE IT!!
Old Dec 7, 2011 | 12:49 PM
pettyfog's Avatar
I hate to point out the obvious but the hot water in is supposed to go bottom of core and exit out the top.
If -somehow- the heater hoses are reversed, it will be a never ending battle.
