Weird head light problem, blazer 95
Old Aug 13, 2010 | 05:09 PM
ludvigsen08's Avatar
ludvigsen08 is on a distinguished road
Default Weird head light problem, blazer 95
Chevrolet Blazer 1995 LT My Headlights are dimmed and weak. The High Beam wont work, The Low beam (or Driving lights) are very dimmed. on my headlight button panel. when its on OFF and car is on idle, there used to be driving lights but not anymore. i have to press inn the button with 2 lights icon then the weak driving lights will come on. when i press the high beam, nothing changes. Have me headlight Relay gone bad? where can i find it in my car?
Old Aug 13, 2010 | 05:23 PM
It sounds like you have DRLs (daytime running lights) and may be having a problem with the DRL relay. The DRL relay is located on the convenience center which is located under the passenger side dash behind the glovebox. That could explain the high beam problem, however, it doesn't explain the low beam problem.
If the grounds were problematic, it may explain both problems. There will be a ground on each side near the headlights.
Here are some wiring diagrams that may help. There is one for each of the following: Composite w/ DRL, Sealed w/ DRL, & Sealed w/o DRL
Attached Thumbnails Weird head light problem, blazer 95-95_composite_drl_sch.gif   Weird head light problem, blazer 95-95_sealed_drl_sch.gif   Weird head light problem, blazer 95-95_sealed_nodrl_sch.gif
Old Aug 13, 2010 | 05:38 PM
Great! Many thanks, hopefully i can find a relay here in Norway.
Had little panic when i drove home from my buddy with hardly any lights..
hitting mooses :P
gonna give it a try to morrow
Old Aug 14, 2010 | 08:53 AM
i've changed the Relay the biggest of the 4relays.but no changes still dimm and weak lights. gonna check the connector to se if its bad with yellow rust or what u call it.
but those other 3 smaller ones, are those for interior lights only?
Old Aug 14, 2010 | 09:30 AM
problem solved.
to all of us folks outside USA.
i bought my h4 lights from usa but my car was bought in norway. so due to diffrent system/setup/voltage. my connector got fried!
i replaced with som dirt cheap h4s from the local chop. and replaced the connectors. it worked i can drive at night again..
Old Aug 14, 2010 | 04:20 PM
Sounds good! Glad you found & solved the problem!
Rumblur
May 22, 2013 03:23 PM
echo1
15
Aug 28, 2012 07:56 PM
J.R. Clay
Mar 17, 2011 08:22 PM
mrammo
Feb 12, 2010 07:49 AM
gERgMan
Sep 6, 2008 07:27 PM
