Weird heating issue with 1998 Blazer
I have a slightly strange issue with the heat coming out of the vents. There is always heating coming out but when I go uphill the heat really warms up. I was thinking I had an air lock. Not to sure if that is the issue. I am adding a little coolant every week or so. Had a bad leak at the water pump a year ago and replaced it. The pipes in and out of the core are hot and when you give them a squeeze you can see the fluid level in the rad respond. Thinking I may have a pin hole leak in the core but I don't see any puddles around the vehicle.
Any thoughts would be appreciated
Probably an air bubble in the cooling system, possibly due to the coolant leak. Have you checked the lower intake manifold gaskets for leaks? Also check for coolant in the oil, and a "milkshake" on the under side of the oil cap. Very common for intakes to leak on these, unless/until you install a Felpro MS98002T gasket set.
Manheim
01-29-2012 12:04 AM
pctechdude
10-13-2010 08:56 AM
gERgMan
09-06-2008 07:27 PM
