Weird Power Surging under a load, Ideas?
Old Jan 28, 2007 | 04:15 PM
doublek's Avatar
doublek is an unknown quantity at this point
Default RE: Weird Power Surging under a load, Ideas?
apprecitate it mark. What ill do is take it to the dealership and get them to scan it while its surging to find out which area we are having problems with.
Thanks, if you think of anything else to try please let me know.....
Old Jan 28, 2007 | 04:19 PM
doublek's Avatar
Just a thought to consider, about a month ago the truck completly shut off while driving. What caused the problem was a bad ignition coil wire. I had that replaces and soon after, this issue arrose....Would this leadyou to believe an area assosicated with that?
Thanks!
Old Jan 28, 2007 | 04:20 PM
20Blazer00's Avatar
Check with you local AutoZone or parts stores sometimes they will scan the codes for free or smaller fee than the dealer....
Also if you do find out it is the spider make sure that they replace the old poppet valve style with the new style that has the injectors at the end of the fuel lines...to see what it looks like go to www.acdelco.com and search for part# 217-3028 it will also tell you who in your area can purchase this if the dealer price is to high...with only 46K miles it should still be under warranty...call the service dept of the dealer to find out.
Old Jan 28, 2007 | 04:22 PM
doublek's Avatar
Check the EGR valve on the front of the intake to see if carbon is keeping the pintle open....since this is happening after 5 mins or more then it has to be in the closed loop operation of the vehicle does it do it when completely cold????
When the issue first started yes it ran alot better when it was cold. Now its about 50/50.
Right now there isnt any codes being thrown. The only code ever thrown was the PO128.
Old Jan 28, 2007 | 04:30 PM
doublek's Avatar
Where is the EGR Valve located on these trucks?
Old Jan 28, 2007 | 04:32 PM
20Blazer00's Avatar
It is the big pop can looking thing with the wires coming out of it next to the thermostat housing just under the TB... if there is excessive carbon then i would suggest you get a gun cleaning kit with flexible wire bore brush (12 guage shotgun) and run it down the passage to the manifold and then the smaller size (9mm)?? for the passage to the intake side. The cleaning solution might also work to loosen the carbon but i would get some spray carbon cleaner...
Old Jan 29, 2007 | 11:58 AM
CaboKP's Avatar
CaboKP is an unknown quantity at this point
I had a problem with my TPS (throttle postition sensor). When I would drive on the interstate at around 65mph for over 20 min the next time I accelerated from a stop light the truck would shift very hard. It shifted hard enough the tires would chirp. The tach was also a little off. The part only cost $30 at a part store and I changed it in 1/2 hour, and I am not a mechanic by any means. Hope this helps.
KP
Old Feb 1, 2007 | 10:30 PM
doublek's Avatar
FIXED....turned out to be a clogged cat.
Not he typical sign, but hey its fixed. Figured it out when i noticed the truck was leaning out real bad when it was doing the surging.
Next time this comes up, this will be something to remember.
Thanks for all the help.
Old Feb 1, 2007 | 10:58 PM
Hmm. Wow. Glad you got it fixed!
gmoney22187
Nov 1, 2011 08:26 AM
EricTrembath
Jan 19, 2009 04:49 PM
jsmz
Oct 19, 2008 02:58 PM
chvy1
May 29, 2008 04:35 PM
Blue Blood
Jun 19, 2007 01:32 PM
