What Could Be the Issue?
Old Aug 20, 2009 | 11:37 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
Default What Could Be the Issue?
Havent really drove the blaze in a while because of the service light has been on. Not very long ago I switched from the stock gas cap to a locking cap. Sometime later my service light came on, I went to autozone and they pulled the code (Cant remember exact one) but they told me it was the gas cap. I told them I replaced it and they told me to spray the cap with wd-40 to "soak the seal." Did that and the code went away, some time after that the code came up again. This time I went to a family mechanic, and what I was told was that the problem was that the "fuel purge valve" and needed replace. I havent ever heard of this so I was wondering what you guys think. I would rather deal with the problem myself because I feel as if our mechanic is kind of shady.
Old Aug 21, 2009 | 12:52 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
try putting back the stock gas cap to see if the problem goes away. you can get a new one at the dealer or used at the junkyards.........
Old Aug 21, 2009 | 12:09 PM
Yeah I tried that and it yielded the same results, the light still on..
Old Aug 21, 2009 | 12:19 PM
dpk1nb's Avatar
dpk1nb is on a distinguished road
You can only use a GM stock gas cap to solve this problem. This is a problem in all new vehicles. Use only GM stock parts for your Blazer. all others will fail eventually
Old Aug 24, 2009 | 02:24 PM
I put the stock one back though like I said, but the lights still on.
Old Aug 24, 2009 | 04:51 PM
mech cb's Avatar
mech cb is on a distinguished road
Your stock one may have an issue with it causing you to still get that light. You'd be better off trying a new one. Keep the package and receipt though just in case it doesn't work.
Also, the WD-40 probably didn't last because WD-40 evaporates pretty quick.
Old Aug 24, 2009 | 08:42 PM
The WD-40 trick will cause the rubber seal to swell a bit allowing it to seal better. It will also cause the seal to degrade quicker.
Your problem is likely the vent solenoid which is located under the back of the truck just ahead of the rear axle either near the frame or on the back of the gas tank (depending on 4wd or 2wd). If you had the specific code, you could run a search. I cannot remember exactly what the code is (something like P0440 or P0442 comes to mind), but I do remember a good discussion on the causes.
Drifter666
Apr 6, 2010 10:24 PM
Hanr3
Jun 7, 2007 12:31 PM
LittleDan911
Suspension Tech
Dec 4, 2005 10:29 PM
arbowman
Aug 25, 2005 07:41 PM
