What does this hose go to?
Old Dec 29, 2013 | 03:05 PM
OraxThay's Avatar
OraxThay is on a distinguished road
Default What does this hose go to?
So I've had this Blazer project for about a month. I'm almost finished with it so that I can sell it and make some money. I've just spent a few hours a day for the past couple of days replacing the heater core. The hardest part is over, but when I went to put the inner fender well back in, I noticed that there was a hose connected to the top of the coolant reservoir (near the cap) that was not connected to anything at the other end. I'm not sure where it's supposed to go; it must have come disconnected when the reservoir was getting knocked around. I also found this little rubber thing that's threaded on one end. It was just laying on the floor near the front of the car. I'm not sure if it's related to the dangling hose or not.
Help me out!
Hose:
Rubber thing:
Oh yeah, I suppose I should mention that it's a 2000 S10 Blazer LS 4WD.
Attached Thumbnails What does this hose go to?-k9ke.th.jpg   What does this hose go to?-r6zw.th.jpg   What does this hose go to?-zvo4.th.jpg
Old Dec 29, 2013 | 03:45 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
the one in you hand is the coolant res over flow doesn't connect to anything. the other 2 pics are a valve steam
Old Dec 30, 2013 | 11:22 AM
OraxThay's Avatar
So it's supposed to just kind of dangle loosely?
A valve stem like for a tire? I wonder how that got up inside there lol.
Old Dec 30, 2013 | 03:57 PM
scottl1346's Avatar
yes just put it so its facing the ground so it can drain. mines in between the wheel well and frame
yes a tire valve steam someone prob put in on the battery or something and it fell or its an old one they pulled out and just tossed it and it ended up where you found it
Old Dec 30, 2013 | 04:16 PM
OraxThay's Avatar
OK cool; thanks
Old Jan 3, 2014 | 02:29 PM
OraxThay's Avatar
Ugh. I've got another thing that I don't know what it is or where it goes. It was laying in the floor under the glove box. I don't remember taking it off of wherever it came from; I took some pretty detailed pictures while disassembling the dash so I could remember where everything went, but it doesn't seem to be in any of my pics. It has a wire attached to it that goes into a hole behind that wiring harness with the screw in the middle of it.
What is it and where does it go?
Attached Thumbnails What does this hose go to?-6z17.th.jpg   What does this hose go to?-yxfz.th.jpg
Old Jan 3, 2014 | 02:51 PM
The part that is in your hand is the blend door actuator and it is fastened to the top of the HVAC housing near the airbag on the passenger side.
Old Jan 3, 2014 | 10:48 PM
OraxThay's Avatar
Thanks for all the help so far, guys. Hopefully this will be my last question. There was one stray plug hanging from inside where the glovebox goes back in. I remember labeling it, but my label fell off and got lost; now I don't know where it plugs in. Stupid me. The first pic is from the front, showing it hanging down from behind the glovebox. The second pic is from below, looking up with the main wiring harness on the left and the heater box on the right.
Again, I really appreciate all the help. I owe you all cookies when I'm finished with this thing.
Attached Thumbnails What does this hose go to?-ywzg.th.jpg   What does this hose go to?-9cd3.th.jpg
Old Jan 4, 2014 | 07:43 PM
OraxThay's Avatar
Bump.
Old Jan 6, 2014 | 11:18 AM
OraxThay's Avatar
Anyone? Please?
