What is idler arm
Old Oct 10, 2014 | 11:44 AM
  #21
LannyL81's Avatar
Very good point....the idler arm joint is a bit difficult to get the grease gun hose on to it; I had not thought of that as I just do the idler arm joint along with the others.
Old Oct 11, 2014 | 12:34 PM
  #22
Spree's Avatar
Spree is on a distinguished road
I had a ball joint go bad at 100,000 miles. Changed all four and idler arm. Get it all done at one time then only one front end alignment to do.
Old Oct 11, 2014 | 06:55 PM
  #23
laxman21's Avatar
laxman21 is on a distinguished road
Old Jun 14, 2015 | 01:14 PM
  #24
AndyBees's Avatar
AndyBees is on a distinguished road
Bringing this Thread back to the top.........
So, looks like my wife's 95 Blazer (under 110k miles) is in need of steering component replacement.
With the front of the vehicle up on stands, I can wiggle the wheel (either side) back and forth about 1/4 to 5/16 inch (give or take a little).
It looks that a bit of the "play" is internal of the steering box.......... is that adjustable? Or, is there some small normal movement within the specs of the steering box?
Lastly, it looks as if the consensus is to replace all four b-joints, all tie rod ends and the idler arm. ........... so, are there any recommended on-line sources?
Old Jun 14, 2015 | 01:49 PM
  #25
newguy's Avatar
Rockauto.com and please please only use moog or OEM, dont cheap out unless you like changing them
Old Jun 14, 2015 | 01:55 PM
  #26
AndyBees's Avatar
Although it has been years (and I mean a long time) since I've done any front-end work on a GM product, this looks fairly straight forward. Is there any tips or "gotcha" things I need to be aware of? Is there anything else that should be replaced?
I realize an alignment will be needed.
The oil line assembly over to the remote oil filter is leaking ...... what part will I be looking for?
Old Jun 14, 2015 | 02:12 PM
  #27
burned's Avatar
burned is on a distinguished road
You're better off checking the steering components while the truck is on the ground, under load. Get her to turn the wheel back and forth while you watch for play. Pay special attention to the pitman arm, idler arm and rag joint of the steering shaft. The box can be adjusted but its recommended you pull it out and do it in a vise. If your adjust it too much it will cause it to bind.
Old Jun 17, 2015 | 08:59 AM
  #28
Tajohns34's Avatar
On my 2000 I replaced the, idler arm, pitman arm, inner tie rod ends, outer tie rod ends, tie rod sleeves, and ball joints. I used all Moog, ACDelco, and Raybestos pro grade.
greatwhite
Nov 28, 2010 11:54 PM
88s10Blazer
Dec 24, 2009 08:43 PM
GMdesigner
Aug 23, 2007 04:57 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
