What keeps frying ignition module
Replaced intake gasket, new coil, crank sensor, fresh tune up complete. runs good but keeps frying modules. All grounds ok.
Code 1351 when it happens. HELP
95 blazer w/ cpi & side tower cap
I guess everyone is stumped also, could a disconnected Knock sensor do it maybe? Im guessing something is spiking the voltage to the module & frying it.
These things are not cheap & I want to solve this...
is the knock sensor disconnected? if it is I would connect it-jp[sm=happybounce.gif]
*Combining Consecutive Posts*
btw-without a manual in front of me-what is a 1351? JP
btw-without a manual in front of me-what is a 1351? JP[sm=badbadbad.gif]
DTC P1351 Ignition Coil Control Circuit High Voltage
The left Knock sensor wiring got damaged & only the right one is connected, this should not fry the module looking at the wiring diagram.
Seems that after the car runs a while is when it happens, just cuts off while driving
By the way I havent found a GOOD flow chart for this code
ignition module failures result most commonly from a fault in the secondary wiring. (i.e. bad wires plugs rotor/cap
adding to my last post - bad components in the secondary ignition will cause high resistance and icm failure
check the ground for the icm w/voltmeter - if you have a drop in voltage more than 0.2 volts you have a improper ground
also, a cause could be charging system ac current - in system if you put a voltmeter to your battery (on ac not dc setting) and get more than 0.5 volts ac then you need to have your alternator checked
good luck
good luck
Brian5792
10-24-2018 11:34 AM
Terryh1968
02-14-2008 09:06 PM
USMaverick101
10-31-2006 03:10 AM
USMaverick101
10-29-2006 10:29 AM
jerickso
04-20-2006 11:05 PM
