What means L35?
Old Dec 16, 2008 | 09:54 AM
crodv's Avatar
crodv is an unknown quantity at this point
Default What means L35?
Hi all,
I am looking for a fuel pump for my 98 LS Blazer, I have found 2 so far, with different vendor codes (M85 and M112, both are ACDelco) and the only difference I see in descriptions is the L35:
1998 CHEVROLET BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W Vendor code: M112
1998 CHEVROLET BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W Vendor code: M85
Sorry I am a beginner on this but, what does it mean L35 ???
PD: My truck has W in the 8th digit of the VIN (I guess both fuel pumps will work... right ? )
Old Dec 16, 2008 | 10:05 AM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Default RE: What means L35?
L35 is a specific engine, open your glovebox and look at the sticker with rpo codes on it if you have that particular engine you will see L35 as one of the codes.
Old Dec 16, 2008 | 10:10 AM
crodv's Avatar
Thanks a lot!! I'll check out this. I am afraid that I'm bidding on ebay for a fuel pump and just noticed this little difference, I don't want to get an incorrect pump.
In case I don't have this sticker... is there any other way to know what engine I have?
Old Dec 16, 2008 | 10:52 AM
WolfPack's Avatar
I thought all 2nd gen blazers had the L35 engine?
Old Dec 16, 2008 | 11:13 AM
crodv's Avatar
Differences I have found so far is that MU85 is for 18 gallons tank and MU112 for L35 engines, I have to check out what is mine so.
Old Dec 16, 2008 | 11:26 AM
They do.
To the OP, you have some incomplete information on those two pump options.
ACDELCO Part # MU85 {#25176789}
MODULE,F/TNK F/PMP(SENDER & PUMP) 4 DOOR; w/18 GAL TK(NE2); INCLS SEAL; w/o LOW LUBRICITY FUEL SYS SENDER(K55)
ACDELCO Part # MU112 {#25178731}
MODULE,F/TNK F/PMP(SENDER & PUMP) 4 DOOR; CODE SFG, SFU; w/o LOW LUBRICITY FUEL SYS SENDER(K55) or 18 GAL TK(NE2)
The MU112 has an application range of 97-98. It looks as though sometime in 98, the MU85 pump replaced the MU112. With the high likelihood of wiring changes, you really should first look at your pump to determine if it has the broadcast code of SFG or SFU on it which would identify it as being the later MU112 pump.
Old Dec 16, 2008 | 11:43 AM
crodv's Avatar
Thanks a lot, so the only answer is getting the pump out and checking those codes. So (sorry for my ignorance) I'll be looking for an sticker that says SFG or SFU ??
Thanks
ChevyBlazerChick
The Chop Shop
14
Oct 29, 2010 04:50 PM
2002XTREME
Feb 2, 2009 06:01 PM
1996blazer
Dec 18, 2008 07:01 PM
94blueknight
Jan 12, 2008 12:19 AM
IssacGumm
Nov 22, 2007 04:07 PM
