what size axle do i have
Old Dec 14, 2006 | 08:15 PM
mic_detonator's Avatar
mic_detonator is an unknown quantity at this point
Default what size axle do i have
what pattern or letterin the vin numer will "decode" such information for me, i need to know if i have a 7 5/8 or 8 somthing inch rear end??? bc i have a bent axle after a curb saw my car and slid out infront of me lmao i know it is a bent axle becuase my spare last week was wobbley as hell
Old Dec 14, 2006 | 09:18 PM
Default RE: what size axle do i have
What year/model/engine/drivetrain config do you have? Please add that information to your signature so we can better help you.
All rear axles are identified by a broadcast code on the right axle tube near the carrier. The rear axle identification and manufacturer's codes must be known before attempting to adjust or to repair axle shafts or the rear axle case assembly. Rear axle ratio, differential type, manufacturer, and build date information is stamped on the right axle tube on the forward side.
In order to verity reports made on rear axle assemblies, include full code letters and build date numbers.
There have been a few posts on axle identification. If you have a ZR2 (RPO code ZR2), then you will have the 8-1/2" rear diff. If not, then you'll have the 7-5/8" rear diff. The number of splines on the axle shaft really depends on the year and it seems that in the transition from 1st gen to 2nd gen that they intermixed the different # of splines... There should be a tag on the rear axle that will have some info on it.
To check what gear ratio you have, check your RPO codes.
If you have something else to drive, I would suggest you pull the axle and count the splines before ordering the replacement. It is possible that the dealership may be able to tell from the VIN number, but that would only be if it were new enough to still be in their database.
Your VIN consists of:
  1. Country of Origin
  2. Manufacturer
  3. Make
  4. GVWR/Brake System
  5. Truck Line/Chassis Type
  6. Series
  7. Body Type
  8. Engine Type
  9. Check Digit
  10. Model Year
  11. Plant Location
  12. Plant Sequence Number (positions 12-17)
Good luck!
Old Dec 14, 2006 | 10:26 PM
I have a 4.3 1997 4 door lt regular NOT ZR2 (although i wish)I figure ifI am getting new tiresI should look into fixing that... wellI dont have the truck right now but I thinkI have the vin only on paper. just put on a2 inch body got 31's, truckbed coarted the underside andjasper trannyfront end etc. now i need to fix the axle and add my chrome the dif cover oh yeah sattelite radio and cd player oh yeah!!! S. forsuper U forutilitarian or utilisV for vegabond in the forest
Old Dec 15, 2006 | 01:40 PM
4lowlife's Avatar
A 28 spline at least.
chowell
Mar 6, 2021 09:47 PM
thrandall
May 3, 2013 04:54 PM
blajeans
Jan 9, 2013 12:58 PM
LucasMI
Jan 2, 2012 02:15 PM
jmaynard
Jul 12, 2011 01:03 PM
