What are these parts?!
So I have a couple parts on my 2001 Blazer LT that I'm not sure what they are. I need help with figuring out what to replaced and where to get it, and then I need someone's help to figure out what something else is. But here are some pics with some details about the parts.
This picture if of some sort of bushing that I am missing, I'm just not sure what it is or where to get it. Does anybody know what this is called. This is located on the front of the truck btw: http://i1107.photobucket.com/albums/...IMAG0114-1.jpg This picture is of some sort of rubber piping that just sits where my oil filter is..It looks to go somewhere, but I have no idea what it would go to Does everyone have this, or is this suppose to hook to something: http://i1107.photobucket.com/albums/...IMAG0116-1.jpg And here it is again: http://i1107.photobucket.com/albums/...5/IMAG0117.jpg So yeah, if anybody knows what these are that would be awesome! |
the 1st picture is the front suspension bump stop. Can be found in the self help area of auto parts store if the parts store doesn't carry the exact OEM part. You can try and match them if the other side is good.
Search: bump stop | Suspension Bump Stop | AutoZone.com The last picture I'm not sure of trace it back to where it connects to something to see what it connects to. May be a part of the SMOG system that has been disconnected or removed?? |
Yep, the first is a bump stop, I just replaced both of mine. Got them from rock auto as stock replacements. Not too bad on price either, only $7.00 a piece.
But that 2nd and 3rd pic, I'd do what's mentioned above, I sure don't have a hose like that running down by my oil filter! :icon_shrug: |
Originally Posted by wrenchturner3529
(Post 435117)
As stated, #1 is the bump stop and #2 & #3 look to be the intake hose for the AIR pump which, if disconnected, would not trigger a code right away, but may allow water/debris into the pump causing problems down the road. If it is the intake hose, it wouldn't be connected to anything else on the other end. It runs from the AIR pump up to along the passenger side of the radiator, about halfway up. This being disconnected will not cause a light in and of itself.
Originally Posted by swartlkk
(Post 435154)
(Post 435154)
Passenger side of the radiator shroud about half way down next to the fan, ought to be 2 small holes where there was a zip tie holding it up.
Originally Posted by RonJon
(Post 435383)
