What years?
Old Sep 22, 2013 | 07:26 PM
ol' grouch's Avatar
ol' grouch is on a distinguished road
Default What years?
What year engines will drop into a '96 4X4 Blazer? I fixed everything up on my truck and yesterday I started getting noise out of the engine. Bummer! In the space of 5 miles, it got a lot louder. It's coming out of the bottom of the oil pan in the front. I'm thinking either a timing chain coming apart or a rod bearing going.
I'm of two minds about fixing this thing. I've spent a bunch of money on it the last few months and now this. Drives great. I've even changed it over to the later (2002) style injection system.
Old Sep 22, 2013 | 08:02 PM
rexazz2's Avatar
time for a V8 ??
Old Sep 22, 2013 | 09:33 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
I believe its up to 98 without any changes.Search the forums or google to make sure though.People have used later model engines but with minor mods.
Old Sep 22, 2013 | 09:34 PM
1996 would be the easiest. Next option would be 1997, or 1998, and you'll most likely need the PCM and wire harness from it. 1999 has secondary air, so not a good choice. The "X" engine will work but, you'll need to use the PCM and wire harness from it, and rewire some stuff, ("X" engine has the injector upgrade, no secondary air, and does not have an EGR valve).
Old Sep 23, 2013 | 07:58 PM
ol' grouch's Avatar
Originally Posted by rexazz2
time for a V8 ??
I just don't want the hassle of converting it. I'm not even sure I want the trouble of swapping the engine. For power I've got a '75 Camaro with a really nasty V-8 in it. Between that and the 4.11 positrac rear end, I have to be careful with the throttle or I leave twin black marks on the drive. The lady friend is griping about the time I spend on the Camaro and now I have a driveway queen with the Blazer.
Old Sep 23, 2013 | 08:55 PM
Just thinking.... 96 & 97 are nearly identical. Both of them have 4 oxygen sensors. 98 and newer only has 3 so you'd definitely need the 98 PCM and wire harness.
Old Sep 24, 2013 | 06:54 AM
xillzxnickx's Avatar
xillzxnickx is an unknown quantity at this point
I have a 1997 and I believe I only have 3 o2s
Old Sep 24, 2013 | 01:53 PM
96 & 97 are the only two years that have 4 oxygen sensors. B1S2 was eliminated on 98 and newer.
TheNick
May 8, 2008 08:49 AM
black powder
Apr 21, 2008 01:47 AM
cj_feltner
Sep 20, 2007 05:30 PM
Bojib
Jun 21, 2007 12:28 PM
TTA89
Engine & Internal
Nov 30, 2005 03:47 PM
