What's this called? (NO pics...)
Old Apr 25, 2016 | 09:05 PM
pjf1313's Avatar
pjf1313 is on a distinguished road
Question What's this called? (NO pics...)
Welp, after 4 months and all of 135 miles on my new-to-me '99 ZR-2, I finally re-fitted/up graded the "Spyder"
Between s%#& weather, time-off of work, and the "K" deciding to run like s&^$ when warmed up, I had to tackle it.
After about 6 hours (taking my time- not to f. things up more) and getting it running again, I can hear an obvious vacuum leak.
The leak is coming from the upper manifold. It's a 90 degree fitting that supplies vacuum to the brake booster. It's located just to the drivers side of the injector connector, and to the right of the PVC valve. 1/8th turn to lock in, with a locking tab. I removed it when I took off the plenum. The "O" ring is shot - too loose to fit snugly onto this mystery fitting, and bunches up/goes on top of the plenum, hence creating a very noticeable vac leak.
What is this fitting called?
To me, it was Orange in color at one time, by the out-line in the plastic manifold, but Black (and loose) now.
Does it need to be fuel rated, or can any "off-the-shelf" "O" ring do?
Thanks
P.J.
P.S. - SPECS - 1999 ZR-2, 4.3l, 4-button 4x4, Auto 4L60-E, 203,000 miles, bunch of new service parts....
P.P.S. - yeah, I've got shop manuals, but 32 miles away don't do me any good
Old Apr 25, 2016 | 11:39 PM
AJBert's Avatar
Off the shelf will work just fine.
Old Apr 26, 2016 | 12:44 AM
pjf1313's Avatar
Thanx Bert..
Going to the local, " hole-in-the-wall" shop in the AM, since they, AZ, and Advance, where closed when I packed up the tools at 7PM ish - what nerve!!! At least the H-I-W opens @ 6am... one of the reasons I go there, and FREE delivery(*)
P.J
* - '13 they DELIVERED to me, in a private residence, a t-stat and 2 gals of antifreeze, 25 minutes after opening, in a minus-teen morning... They will always be my first-go place...
S10Blazer
Jan 19, 2009 07:20 PM
copper_eyes
Mar 5, 2008 04:58 PM
rastaskater
Mar 3, 2008 04:48 PM
EuroGoldLS
Apr 4, 2007 11:34 PM
vagnozzi
Mar 8, 2007 12:26 PM
