whats the name of this?
Old Oct 14, 2010 | 09:22 AM
iloveblazers's Avatar
iloveblazers is on a distinguished road
Default whats the name of this?
my dad thinks its called the main power harness but i googled it and i am not getting anything. Its all the wires that run from the power center across the firewall to the computer and runs to everything in between them.
We tried to fix the wires by cleaning them and wrapping them in electrical tape, but i went to run the wipers this morning and they only go in 1 speed. I have replaced the wiper motor and the turn signal switch.
Old Oct 14, 2010 | 09:36 AM
What are you working on? I'm guessing a 98+.
There are separate circuits from the fuse/relay center for each fuse/relay located therein. Which ones are you having trouble with?
Old Oct 14, 2010 | 09:38 AM
sorry, it is a 98. I am having problems with which ever one controls the wipers. I am only getting 1 speed.
Old Oct 14, 2010 | 09:47 AM
I know that you said that you had replaced the wiper motor, but was it with a new one? If so, it should have come with a new pulse board (what the electrical connection plugs into). Regardless, check out this thread:
Fix for cold solders in the Wiper Motor
You could also check all of the wiring in the attached diagram:
Old Oct 14, 2010 | 09:49 AM
thank you. i bought a new ac delco motor.
forgot to mention this. When my dad cleaned the wires and wrapped them in electrical tape, the wipers worked properly. Now they dont.
Since the wires were bare in some places and then having problems with the horn, i figured i need that whole set of new wires.
Last edited by swartlkk; Oct 14, 2010 at 09:59 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Oct 14, 2010 | 09:58 AM
From the sound of it, you need to cut out those bad/bare wires and splice in new ones. Wrapping things with electrical tape really doesn't seal them up. Corrosion can still run rampant inside the tape and cause further problems. Some wire and a few 3M shrink wrap butt connectors should get you all fixed back up. Try to stagger your joints so you do not have a large bulge in the harness.
Also, rather than posting back to back since the rules do call this out, please edit your post to provide additional information. Thanks and good luck with your problem.
Old Oct 14, 2010 | 10:01 AM
thanks. sorry about that
0ffroader
May 4, 2013 12:25 AM
jagblazer01
Feb 15, 2010 07:44 AM
oktain
Nov 15, 2009 06:47 AM
midnightmekanik
Oct 8, 2009 08:32 PM
pigmak
Jun 30, 2008 08:20 PM
