where is it at ?
Old Jun 26, 2007 | 05:44 PM
allen68's Avatar
allen68 is an unknown quantity at this point
Default where is it at ?
can someone tell me were the orifice tube is on a 2000 blazer thank
Old Jun 26, 2007 | 06:28 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: where is it at ?
Welcome, the orifice tube is in the inlet pipe of the evaporator core.The fitting that you need to access to change it isdirectly under the accumulator (silver can looking thing on the passenger's side of the engine compartment, has a switch and a hose and a service fitting in it). Disconnectthe pipe under the accumulator, and the orifice tube is inside the pipe, but pay close attention as to which end you pull out, you can install these backwards and it will not funtion properly.
Old Jun 26, 2007 | 07:22 PM
I'll state the obvious... The refridgerant must be recovered prior to opening up the system to replace the orifice tube...
Old Mar 13, 2008 | 12:31 AM
rdhack's Avatar
rdhack is an unknown quantity at this point
I am wondering and thinking of trying a retrofit myself.......Does onehave to havea special tool to remove the orifice tube? I have seen the tools on the internet but wasn't going to buy one unless I had too. Any other way to get it out?
retrofitting a 1991 s-10 Blazer
Old Mar 13, 2008 | 08:58 AM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
ORIGINAL: allen68
I don't know but it's making me horny
Welcome
Zed
Old Mar 13, 2008 | 12:58 PM
DCFluX's Avatar
DCFluX is an unknown quantity at this point
I use a set of hemistats, but you may need the tool depending on how stuck it is.
