Where does this broken wire go? HELP!
Old Oct 14, 2009 | 05:00 PM
jrodm12's Avatar
jrodm12 is on a distinguished road
Default Where does this broken wire go? HELP!
I will upload pics when i get home. But i started my 99 blazer today and it was misfiring. Great. So i go to my moms to get some tools and pull the cap off and see there is alot of corrosion on the terminals and rotor looks like it could be replaced as well. So im looking around by the distributor and i see a Black wire with a white stripe that is bare on the end and not connected to anything. I looked at the ignition block in the distributor all wires there. I also looked at the connector going to to oil pressure sensor and all good there too. I see that there are two wires that seem to be grounded to the metal part of the intake mani on the passenger side near the distributor. Is this black/white wire also a ground? Can someone with a like year blazer just peak under there hood and take a look? You should be able to see it from passenger fender looking back toward the distributor. I can post some pics later tonight. Thanks in advance for any help at all.
Old Oct 14, 2009 | 06:25 PM
jrodm12's Avatar
Here is a video i shot of the area and wire that is disconnected.
http://www.youtube.com/watch?v=hX-41JUXrhc
Here some some pictures.
http://img517.imageshack.us/i/101409143000.jpg/
http://img517.imageshack.us/i/101409143001.jpg/
Old Oct 14, 2009 | 07:04 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
cant really tell what that wire goes to from the pics but it may be a ground wire to the back of the head..the wires that ground are small and bunched up on a couple 5/16 or 3/8 ring connectors.or it could be a sensor wire...(stretch it to see whats near by).misfires will come from no spark ,bad plugs /wires, cap n rotor,fuel issues.lack of combustion..the list goes on..without more info my guess is as good as yours...
Old Oct 14, 2009 | 07:07 PM
I was going to say that as well. Sure looks like it was pulled out of a connector of some sort.
Old Oct 14, 2009 | 07:13 PM
jrodm12's Avatar
Car seems to run great now. If either of you have them same gen blazer could you go n look in that area n tell me if there are 2 or 3 ground wires in that area they attach to the instake not the back of the block. I check all the sensors around there like the ignition module thing in the distributor and the oil pressure sensor... I can't see any other wires or sensors in that area.
Old Oct 14, 2009 | 10:10 PM
reelbroke2's Avatar
there are ground wires on the back of each head
Old Oct 14, 2009 | 10:52 PM
jrodm12's Avatar
Ok but what i want to know is if this wire is indeed a ground cause if it is ill just ground it to the block elsewhere.
stang_me1990
Aug 15, 2013 04:21 PM
xillzxnickx
Oct 17, 2012 11:38 AM
blazerowner65
Oct 10, 2011 03:09 PM
DJ 4x4
Sep 26, 2011 09:44 PM
bubba181x1
Mar 12, 2008 02:05 AM
