Where does this go?
While under the hood today looking for a leak...I noticed this little baby unplugged...I looked around and cannot see where it should be...It has one lime green wire and one green wire with a white stripe. If you follow it back it hooks into the same wire bundle as the two connectors that go on the air line coming from the air filter box.
If you could get under there...let me know where the other side comes from...
For those that need to know...after doing the intake manifold gaskets..my mechanic was like...where does this go. When he looked....the guy who replaced my AC Compressor didn't take the old high pressure switch off of my old compressor...my new one doesn't have it. Basically I was wondering why my compressor cycled on and off all the time. Looks like I am going to have to get it fixed before I end up burning out my compressor.
I was gonna say A/C compressor. Anyways im surprised it ran at all as that switch is normally closed i believe. Which means that you would have had to jumper that plug out to get your A/C to work. Its Used for protection of over-pressurizing the system and will not burn anything out unless there should be a failure .
Amelia23
Sep 29, 2012 05:31 PM
camino88
Feb 7, 2010 10:58 PM
jspafford
Jun 10, 2009 04:51 PM
