Where is the map snesor?
Old May 21, 2007 | 03:28 PM
ivannj's Avatar
ivannj is an unknown quantity at this point
Default Where is the map snesor?
Would someone tell me in detail where the map sensor is and what is needed to change it? Appreciate the help Blazerforum.com!
Old May 21, 2007 | 03:39 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: Where is the map snesor?
I am not sure where it is, or how to change it, but if your compass is just displaying C then look in the owners manual on how to recalibrate it. I believe you muct be on flat ground in a parking lot and drive around in 3 circles. The owners manual should tell you those directions. Also there is nothing in the haynes auto repair manual mentioning the compass and where its at. sorry, maybe someone else will know.
-Lenny
It looks like this:
Photos courtesy of NapaOnline.com
And is located here (passenger side of the plenum):
You simply unplug the sensor wiring and pull up on the sensor. The only thing holding it in place is the fit of the seal into the upper plenum. Use a bit of oil on the seal to ease installation.
*EDIT* The MAP sensor has nothing to do with the compass... It is the Manifold Absolute Pressure sensor for the engine. It is used in conjunction with the TPS, MAF, HO2S, and the Knock sensors to ensure that the engine is running appropriately for the given situation.
swartlkk
Aug 12, 2021 03:49 AM
jigger
Nov 9, 2009 12:05 AM
01extreme
Jun 10, 2007 07:52 PM
Aquahallic
Aug 19, 2006 11:20 PM
swdockter
Mar 29, 2006 11:41 PM
