Whining noise under dash
Old Feb 26, 2014 | 10:37 AM
03BlazerMan's Avatar
03BlazerMan is on a distinguished road
Cool Whining noise under dash
Hi guys, I'm new to the forums and it won't allow me to post a new thread and I've searched here for similar problems, but haven't quite found it.
I'm hearing a whining noise down near the pedals on my 03' Blazer LS. It's not coming from the engine, it's actually right down under the steering wheel. It sounds like it could even be electronic, if that makes sense. It isn't constant and doesn't happen throughout the entire duration of my drive. It starts off pretty low pitched and then gets higher, then lower and stops. The whining noise lasts approximately 5-7 seconds.
Anyone ever heard of this? Sound familiar at all? I just bought this truck, and if it's something serious I'd like to fix it. Thank you
Old Feb 26, 2014 | 05:25 PM
justaguywithtools's Avatar
justaguywithtools is on a distinguished road
when the noise starts, listen under the vehicle near the front floor pan. see if the whine is coming from the trans bellhousing area. had a oil pump on the trans make a whine like that and echo through the firewall.
Old Feb 27, 2014 | 04:27 PM
Hmm... I can only try, sometimes it happens and ends so fast I may not get a chance to do that. Every time i start the truck from here on out, I'll wait until I pull out of the driveway and see if it happens in idle.
Thank you!
Old Mar 6, 2014 | 08:03 AM
sir otto's Avatar
sir otto is an unknown quantity at this point
Look to see if your throttle cable is resting against your PCV valve. Makes a very very annoying sound that comes through the cluster and below the wheels at the firewall
Old Mar 6, 2014 | 08:28 AM
newguy's Avatar
A dirty trans filter can make the pump whine, Also , could it be your girlfriend/wife? LOL
spiritscense
May 29, 2012 11:04 PM
The89Blazer
Dec 12, 2010 07:46 PM
jdpilot
Jun 12, 2009 09:14 PM
steve2208
May 20, 2009 12:18 PM
bl_zer
Apr 17, 2008 05:37 PM
