Whining/Whistle Sound
Old Feb 4, 2008 | 06:11 AM
J.C.Vice's Avatar
J.C.Vice is an unknown quantity at this point
Default Whining/Whistle Sound
2000 S10 Blazer 2 wheel drive
When accelerating the whining sound is high and then seems decrees when slowing down. The sound also happens when in park while pressing down the gas peddle. Any ideas? I’m thinking vacuum leak but I am not a mechanic?
Old Feb 4, 2008 | 07:00 AM
thegr81's Avatar
Default RE: Whining/Whistle Sound
Can you give a guess as to where the whinning sound seems to be coming from???
Old Feb 4, 2008 | 07:31 AM
FirehawkNS's Avatar
FirehawkNS is an unknown quantity at this point
First thing I think when people say whining is Alternator. But Whistling wouldsound morelike an air leak somewhere.
Old Feb 4, 2008 | 05:36 PM
Calgary ZR2's Avatar
Calgary ZR2 is an unknown quantity at this point
It may possibly be the brake booster.
My booster is making a rattling sound that I hear through the dashboard. While researching the problem I ran across many owners who are hearing a whining or whistling sound from the booster.
Old Feb 4, 2008 | 10:24 PM
ltown21's Avatar
ltown21 is an unknown quantity at this point
mine whirs slightly but i don't mind it it seems to be coming from the front of the engine like a belt or pulley but hey could be my alternator cause its going out.
EDIT also I have the rattle from the brake booster which is annoying! any solution?
Old Feb 5, 2008 | 12:07 AM
It makes sence too.
I was also told that the belt tensioner may be a cause of a whining sound. It would be a rapid sound that would change during different driving canditions. The booster may remain constant with the vacume.
As for fixing the rattling. You really can't. You have to change the booster or the valves may fail soon and leave you with no brake boost. This seems to be a problem for many of the GM SUVs and trucks. The failure occures long enough after the original warranty and since it does not trigger a code the extended warranty companies don't cover it.
Old Feb 5, 2008 | 02:29 PM
ltown21's Avatar
meh ill let both go no sence in fixing what isn't broken
Old Feb 5, 2008 | 08:05 PM
woodsballr's Avatar
woodsballr is an unknown quantity at this point
ok i feel pretty good cause now heres a problem i think i can use my limited mechanical knowledge and experience to help fix. i'm having the same problem with my truck. the sound is coming through my speakers. from what i've been able to gather it's feedback or somesuch thing and it's being caused by the alternator. so now i get to spend $70 on a new alternator. my problem aside that should be your solution. also check your battery charge guage meterie thingie (thats a technical term by the way) mine is spending most of the time in the red but if yours is up then theres some corroborating evidence.
good luck
Old Feb 6, 2008 | 04:56 PM
TheJuicer's Avatar
TheJuicer is an unknown quantity at this point
I also had a whining sound which was coming from the front of the car. I had also noticed my interior lights dimming on and off when coming to stops and when using the brakes. I tested the alternator and it was going bad. Replaced it and the whining problem went away.
Old Feb 6, 2008 | 07:54 PM
ltown21's Avatar
well my alternator is fine for the most part but every so often, it wont charge at idle.[>:]
