Whirring noise only when accelerating
Old Jan 31, 2013 | 09:56 AM
kbonbrake's Avatar
kbonbrake is on a distinguished road
Default Whirring noise only when accelerating
About two weeks ago I noticed a whirring noise coming from under the truck towards the front end it sounds like. It's a 1999 4X4 4 door. It only occurs when accelerating. When you let off the gas there is about a second delay then it goes away. It does it from about 30 - 35 MPH and again at about 55 - 60 MPH. Also right before coming to a stop as it shifts down into 1st (I assume). My thoughts are either the transmission or front differential. I checked the transmission fluid and it was low so I added some, no change. I plan on a fluid an filter change as soon as I get some time. Any ideas from the experts out there?
Old Jan 31, 2013 | 10:00 AM
chris015's Avatar
could be the fan clutch. which is normal as all of mine has always done it which gets annoying. do you have 4wd?
Old Jan 31, 2013 | 10:44 AM
kbonbrake's Avatar
Yes, it is 4wd.
Old Jan 31, 2013 | 10:49 AM
LannyL81's Avatar
Does it sound like the engine fan or a gear whine?
Old Jan 31, 2013 | 10:54 AM
kbonbrake's Avatar
It's kind of hard to describe it is higher pitched at higher speeds. It sounds kind of like a high pitched buzz or hum.
Old Jan 31, 2013 | 12:56 PM
LannyL81's Avatar
Probably as suggested above, fan clutch. Normal operation for some reason on the Blazer...do not know why, but it is.
You can check the fan clutch: with engine OFF turn the fan by hand...should be a slight resistance.
Old Jan 31, 2013 | 01:05 PM
kbonbrake's Avatar
I checked the fan by turning it by hand. There was some resistance but it wasn't constant. It ranged from a considerable amount to almost none depending on where in the revolution it was. Does this mean that it is bad?
Old Jan 31, 2013 | 05:27 PM
Is the noise, vehicle speed related, or engine speed related?
edit: Those are typical speeds for a universal joint in the rear driveshaft to make noise or vibrate. Have you checked them?
Old Jan 31, 2013 | 06:25 PM
kbonbrake's Avatar
It is vehicle speed related. Even in different gears it comes at the same speeds. I didn't think of that.
Old Jan 31, 2013 | 06:26 PM
Diaita's Avatar
Power steering fluid low? Alternator?
