Why is my rear end low
Old Oct 24, 2006 | 01:53 PM
batzer's Avatar
batzer is an unknown quantity at this point
Default Why is my rear end low
Hope you can give me some ideas. My '99 4X4 looks as if the back end of the truck is lower than the front. It looks like it is always going up a hill. I haven't had a chance to look at this yet but could you give me some ideas on where to start.
Thanks.
Old Oct 24, 2006 | 02:00 PM
93s15jimmy's Avatar
93s15jimmy is an unknown quantity at this point
Default RE: Why is my rear end low
check the leaf springs...thats all i can think of. oh and check the tire pressure. just some suggestions.
Old Oct 24, 2006 | 02:11 PM
yeah, loose or broken leaf springs will cause the rear end to sag.
Old Jan 6, 2007 | 05:28 AM
batzer's Avatar
I had a look at the leaf springs and all seems fine. I keep hearing about lifting the torsion bars to raise the front end a bit. I am wondering if this may have been done before I got the Blazer. What is that all about??
Old Jan 6, 2007 | 06:27 AM
Chevy Lover's Avatar
2possible problems could be that the rear springs have sagged or the torsion bars have been adjusted.
Take some measurements on level ground and let us know if it really is low.
Old Jan 6, 2007 | 09:21 AM
rooster's Avatar
rooster is an unknown quantity at this point
if u or whoever owned the truck first hauled a trailer then ur leaf springs could have flattened out. or maybe alot of friends on long road trips could do it too. like it happened to me.
now u could find a shop that would re-arch ur springs or pickup new ones for around 80-100 bucks, i think its jc whiney that has that price but i could be wrong.
Old Jan 6, 2007 | 09:25 AM
tammikm's Avatar
tammikm is an unknown quantity at this point
how high from the ground should a stock blazer sit? and where do you measure from.
thanks
Old Jan 6, 2007 | 09:38 AM
rooster's Avatar
i believe it is ground to frame, behind the front wheel and in front of the rear wheel. have urself a ruler that is marked down to the 16th of a inch and take a close accurate look. and its ok if the back is slightly higher, it compensates for any weight that might be loaded. but u dont want it to be too high or else it will eat away at ur front brakes and would suck around corners.
brino1
Feb 25, 2011 08:05 PM
blazinloud
Jan 5, 2011 10:29 AM
bigdaddykane93
Jul 13, 2010 01:37 AM
cide
Mar 23, 2009 10:57 AM
