Will not pull
Old Feb 18, 2020 | 05:58 PM
Bovandy88's Avatar
Bovandy88 is on a distinguished road
Default Will not pull
Hi I have a 1999 Chevy Blazer 4.3 4x4 automatic transmission. I just got finished doing intake manifold gasket job after getting everything put back together I cranked ran good drove it for about a quarter mile then rpm was going up but not going very fast in a couple min it quit pulling all together in any gear when you shift it will not move. It was moving and shifting fine before the intake job did I forget to plug something back up and I did check the fluid and it was full. Any suggestions?
Old Feb 18, 2020 | 06:52 PM
GeorgeLG's Avatar
Any codes?
George
Old Feb 18, 2020 | 07:12 PM
Bovandy88's Avatar
Service engine light is on but I do not own a scanner
Old Feb 18, 2020 | 07:33 PM
Bovandy88's Avatar
Part store friend is going to bring theirs tomorrow in the mean time anything you can think of. Just got in it it been setting for a few hours something will not move in any gear don't even feel it trying to shift.
Old Feb 18, 2020 | 09:24 PM
GeorgeLG's Avatar
So the engine runs, you can move through all the gears at idle, in any gear the engine revs up but the truck will not move?
George
Old Feb 19, 2020 | 05:26 AM
Bovandy88's Avatar
That is correct.
Old Feb 19, 2020 | 07:27 AM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
Wonder if for some strange reason the shifting linkage came unhooked below @ the side of the transmission..I have seen that happen quite a few times where the parking pawl 'ball' deteriorates allowing the linkage to come off...Weird the timing though...although timing sometimes means nothing....just a thought.....have someone move the shifter and watch below to see if the arm is connected to the side of the trans....Jerry
Old Feb 19, 2020 | 08:28 AM
GeorgeLG's Avatar
In addition to the linkage, have you checked the trans fluid level?
George
Old Feb 19, 2020 | 08:38 AM
Bovandy88's Avatar
Checked it before I cranked it and it was showing about a half inch past hot gonna let I run and warm up and see if it goes down
Old Feb 19, 2020 | 08:55 AM
Bovandy88's Avatar
Been running a while I checked it fluid is not moving on the dip stick still showing about a half inch past full reckon it's the pump not working
