Will not pull
Never worked on this transmission. Maybe another member who has dealt with the wiring and harnesses can advise you on location and routing. I would start with any harnesses near your work that routes to the trans. I believe that the main harness is a round plug on the side of the trans case. Look for loose connectors, frayed or broken wires, etc. if you want to search the Google, it’s a 4L60E trans.
George
George
I don't think its brakes I can feel it shift forward now but not reverse when you give it a lot of gas it will move but trans sputters then it clears up and moves but soon as you stop it does it again forward is not as bad but does not have a hard jerk when you put it into forward or reverse like it did is there anything electrical or sensor that controls what gear your in that's on the outside somewhere I thought water may of fried something where I drained everything from doing the intake gasket job
No codes yesterday service engine light is off now still acts the same but has gotten a little better took a line from the radiator and cranked the engine and it squirted out fluid so pump is working.
