Windshield washer fluid pump
Alright. Just got my vehicle, thought the windshield fluid was empty, filled it. Turns out the pump is bad. Where is it and is it hard to replace?
thanks! |
RE: Windshield washer fluid pump
2 pumps are located under the washer resivor. One is for front windshield and other for back window.
Does the back one work? If not, check fuses. |
You can get the pumps from Napa. Theyre not expensive, I think they were like $10-15 each when I replaced mine. Just disconnect the lines and electrical wires and then just pull the pumps out of the reservoir, its real easy.
pm sent
Hey, thanks for all the help guys. This forum is already being awesome!
I found the pumps from Napa at 15.33 a piece. Got them changed. Found out that the hose that connects to the sprayer on the rear hatch disconnected itself INSIDE the tailgate structure...Great....So now some 7mm sockets to be found to fix that next weekend. |
