Windshield washer fluid pump
Old Mar 25, 2006 | 03:59 AM
kaindragoon36's Avatar
kaindragoon36 is an unknown quantity at this point
Default Windshield washer fluid pump
Alright. Just got my vehicle, thought the windshield fluid was empty, filled it. Turns out the pump is bad. Where is it and is it hard to replace?
thanks!
Old Mar 25, 2006 | 12:46 PM
tomsblazer's Avatar
tomsblazer is an unknown quantity at this point
Default RE: Windshield washer fluid pump
2 pumps are located under the washer resivor. One is for front windshield and other for back window.
Does the back one work? If not, check fuses.
Old Mar 25, 2006 | 01:17 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
You can get the pumps from Napa. Theyre not expensive, I think they were like $10-15 each when I replaced mine. Just disconnect the lines and electrical wires and then just pull the pumps out of the reservoir, its real easy.
Old Mar 25, 2006 | 03:06 PM
KA3AX's Avatar
KA3AX is an unknown quantity at this point
pm sent
Old Mar 25, 2006 | 04:22 PM
Hey, thanks for all the help guys. This forum is already being awesome!
I found the pumps from Napa at 15.33 a piece. Got them changed. Found out that the hose that connects to the sprayer on the rear hatch disconnected itself INSIDE the tailgate structure...Great....So now some 7mm sockets to be found to fix that next weekend.
88blackzcand95blazer
Feb 12, 2009 03:42 PM
Matty Kling
Oct 10, 2007 01:25 PM
carlo
Jan 1, 2007 03:03 PM
jboy76
Jun 7, 2006 09:25 PM
fruccoman
Feb 15, 2006 07:08 PM
