Wiper problem - not the usual board issue
Old Sep 19, 2012 | 02:35 PM
WorstCases's Avatar
WorstCases is an unknown quantity at this point
Default Wiper problem - not the usual board issue
Hello Folks.
I have a 2000 Blazer.
Had trouble with wiper speeds on the slow/pulsing settings.
Thought it's the pulse board. Soldered first, bought aftermarket second, changed whole motor third and did order a new wiper/turn signal control arm. Problem still persists!
The problem:
If wiper is off and I switch it to any pulsed mode, it won't come on right away, it will only come on when the second wipe would start. As expected, the delay for the initial wipe is shorter on the faster pulsed settings. It comes on as soon as I set it on low/high speed.
What do you guys think? I wonder how to trouble-shoot from here. I have found a wiring diagram (see attachment).
Did measure Voltage on the electrical connector @ motor on the bottom left terminal. This changes voltage as the pulsing speed is changed. It's ranging somewhat between 10.6 and 11.6 - depending on the speed.
Where do I go from here?
File Type: pdf
Old Sep 19, 2012 | 05:18 PM
spittybays
Guest
Posts: n/a
On your diagram try cleaning the grounds labled G104 and G117.
Were did you pull that system wiring pdf from- could use one.
Old Sep 19, 2012 | 09:33 PM
If the "MIST" function and washer work immediately and simutaneously when you operate the "MIST" switch, and low and high speeds work ok, the problem is in the pulse board.
cleburne red
Jun 5, 2016 12:51 AM
insanefirewall
Jun 25, 2014 11:22 AM
jeffintoronto
Aug 27, 2012 10:18 AM
Bowers
Mar 16, 2011 11:19 PM
omalley576
Aug 22, 2007 10:13 PM
