Wipers, and Windows
Old Oct 17, 2007 | 01:50 PM
UrbanOffRoader's Avatar
UrbanOffRoader is an unknown quantity at this point
Default Wipers, and Windows
Hey all,
More problems with my lovely Blazer today.
My wipers aren't working worth poo. They work sometimes, and other times I just hear an annoying buzz but they don't move (it's almost like they are telling me I have answered a game show question incorrect so I will not be rewarded with functioning wipers). If I give my hood a bang they start to work for a while and then fail. If I open the hood and wiggle the connection, they work for a while then quit.
The odd thing is... They work every morning. It seems to be ok after the truck sits overnight.
Would this be the cold solder problem? Or is the motor just shot? This is actually my 3rd motor this year... the last 2 just wouldn't turn off.
Aaaaaaaaand.... problem number 2
My drivers door window just decided to quit working. I parked my truck, rolled up the window, ran inside a store, came out 5 minutes later, started truck,window no workie.
There was no symptoms of a failing motor previously.
When I hit the switch, the dome light dims a bit so I know there is power draw.
Bad connection? Or just bad motor?
M
Old Oct 17, 2007 | 03:28 PM
DCFluX's Avatar
DCFluX is an unknown quantity at this point
Default RE: Wipers, and Windows
Could be cold solder or a bad motor, also you may be having trouble up stream. Put a volt meter on the terminals of the motor and that will tell you alot.
As for your power window:
https://blazerforum.com/m_100007/tm.htm
Old Oct 17, 2007 | 04:07 PM
Thanks. I was dreading a bad window motor.[:@]
I guess I'll do some digging around and test some voltage this weekend.
It's just odd because the window motor was strong and had no issue whatsoever before it quit.
Old Oct 17, 2007 | 05:08 PM
DCFluX's Avatar
My window motor was the exact same way. Although I did have intermitants where it would stop working, luckily in the up position. It was when it just stoped in the mid-way position that I did something about it.
Reviewing the play it could be that dirt got into the worm screw, you might want to try soaking it with some penetrating oil and bounce the switch a couple of times and see if it frees up.
Old Oct 18, 2007 | 08:27 AM
I'm going to rip her apart this weekend and see if I can get to the bottom of it. Thanks for the tip on the worm screw.
The amount of small problems that this blazer has developed in the last few months is gettingstupid already. It's almost like it got jealous of my new car.
The wiper motor was doing it's thing again last night. I popped the hood and gave the connector a wiggle and they worked fine for the rest of the night. Sometimes all it takes is a pothole to get them to stop/start working. I'll run some voltage tests and see if this is a connector, or board issue.
If it's anything more serious than that... I'll just find a reason to park it in my city's "North End" for an hour. Blazers tend to disappear quite quickly in that area.
Thanks for the help
M
Snovelr27
Nov 19, 2017 06:14 PM
prkrgrp
May 26, 2014 09:07 PM
argue_with_a_tree
Feb 28, 2011 05:57 AM
Jonas
Aug 9, 2010 06:29 PM
2003blazer
Dec 30, 2005 12:21 AM
